F.A.S.T. president
![]() Join Date: Sep 2003
what did you grease monkeys get done this weekend
I finshed the body work on the fire wall and spit some epoxy primer on it. Here are a few pics of the project.
Thanks to the body pros... sevt_chevelle, MARTINSR and others for the help with fillers and paints.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 10-05-2007 at 07:12 AM. |
![]() Join Date: Dec 2001
Did a burnout in the parking lot at work and filled the shop with smoke.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
C10 Junkie
added the trim to my front end and the sills on the door frame.
http://67-72chevytrucks.com/vboard/s....php3?t=154412
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck ![]() Former rides: 1967 C10 LWB 1972 C10 LWB 1969 C10 LWB (parts truck) |
#16876
I removed my tool box door, and took it back to the painter so he repair a couple bubbles in his paint.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#5 | |
F.A.S.T. president
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
Car O'Holic
Swapped cabs with one I bought in Dallas TruckinDaddy helped as long as 2 of my buddies everything went well except I smashed my cap and rotor
![]() Join Date: Feb 2001
No grease, but got the new door panels on and the ZR2 waxed. Got a whole week off so who knows????
Seņor Member
Much hacking on the rear suspension. I've got an extra 3" of clearance for the axle and another 3" of drop on the bags. Pretty soon, I should have this thing fairly low
![]() edit: added pic (if anyone is looking for an excellent photographer for weddings, birthdays, etc., you can tell from this gem that I'm your man! ![]() edit: daytime pic
Born a Chevy Man
Had to work on my carb on the '70 Burb. The Eddlebrock still is not running up to par. But I will get it right.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
Where's my beer?
I worked a s@@tload of OT for money to get the Camaro painted, then hauled a load of lumber in the 70 for new railings for the front porch. I got 2 posts set and then it started raining. Fortunatley the wood is salt treated, so it will sit in the truck until tomorrow nite, when it's supposed to be nice weather.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Jamis,
You know you shaved the speedo cable and throttle cable hole right ? Well, I went to my G-Friends grad. 6 hour drive to the school it was most of the weekend. She is now a Vet Tech got 2 of the 4 awards handed out too. Pretty good weekend. Good break fromm the truck. I managed to get the holly 600 rebuilt so I can get rid of the 1406 on my 84 DD. And I just broke the faring die for the 3/16 lines I had to flare. Next weekend I will get lots done though.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Greased the forms,& did concrete around the pool......F... that old truck, I have better things to work on!
http://community.webshots.com/user/hotrodhorn |
weekend work
Pulled the cab off the 67 so I could clean and paint the frame.I also am going get rid of my heater.Im putting one off a fork lift on it takes less room under the dash.
77 swb starting all over again. |
Blue 67
![]() Join Date: Apr 2004
try to restore my relationship!. No luck so far!
#15 |
Member since 2000
Grinding! and some more adjusting. It's been one hell of a week at work so i decided to spend my time in the threaters. if anyone is thinking of seeing the movie CRASH. It's real good.
#16 |
Questionable
Went to pick up a 2-ton Big Red engine hoist from someone 15 miles away for 100 bucks. Only used once. Truck broke down (overheat?) on the way back. Had to sit on it for a few minutes to make the last mile. First time I've gotten the truck out in a month or so.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#17 |
It's Done When It Runs!!
I got most of my Autometer guages put in and wired. I used the 2 5/8 in for the bottom. I still have to get the speedo and tach. Gonna go with the elec. speedo so I'll have to save a few more bucks for that. I also made my 100th post.
#18 |
Keep On Truckin'
Completed wiring for tuned port setup, installed power steering pump pulley, harmonic balancer, steering column, Lokar shifter linkage to 700R4 tranny, wiring for gas tank, In-Line Tube emergency brake cables, rear brake shoes and bent the fu*k out of the completed and painted passenger side rocker panel with the lift (guess I'll fix that next weekend).
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
#19 |
Currently Blazerless
I installed new door panels, a tilt column and new bezel on the GMC, also put new deluxe pedal pads on with stainless trim and painted the clutch & brake swing arms and shifter.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#20 |
Blazerman...those panels rock!!!!!!
#21 |
68cst_ss490
I sold my project...dranks ome beer....not much else... now I am truckless and in the search of a 66-67 chevelle
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
#22 | |
F.A.S.T. president
yep....but only after my haze from all the welding and beer wore off....I noticed I didnt have the hole for the speedo cable. ![]() As far as the throttle hole, I'm going with a cable and this had the rod setup and I need the sqaure hole for the cable. I'm sure when I go to put it back together I will find more holes I should have left alone and some I should have closed. LOL I blame my mistakes on this. I was on vacation when I tackled this job and I only drink when I'm on vacation or not on call for work. need less to say I only drink a couple of beers a month and that day I had six
#23 |
I'm watching you!
Saturday I went to NJ to get the fenders, cab corners, rockers, and few other parts zeeklu (chris) offered me back in Feb. Check out his truck and BSed for a little. Drove home to L-town today to fix the 93's alternator and to get my truck to NEPA this week.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() Last edited by 68haywagon; 05-15-2005 at 11:44 PM. |
#24 | |
Seņor Member
#25 | |
