another frame swap question
i would like to know if anyone has put a 52 gmc or chevy cab and bed on a 68 3/4 ton frame if so what issues came up. or can this swap be done i am ready for all your answers thanks
Sanity is a state of mind
Paul, I was about to ask a similar question about mounting a 50 Panel on a mid seventies chassis. Then I read your post and noticed the lack of replies. I would say in your case it shouldn't be too bad. as you are dealing with a cab instead of a panel. I have done a few swaps in my time but never one that is going to help you or I. If you could find a picture of a early frame and match it up with a pic of a later frame it may speak to you. If you do find a picture of an early frame please PM me and let me know. I can send you a link to a picture with dimensions of the 69 3/4 ton frame.
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1 70 C-10 Panel Vortec V/5spd BW od /307 to 1 70 C-30 9ft stepside dump 350/465/ posi and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs ...o~`o |
![]() Join Date: Apr 2005
Swap
I have seen one that was done that way and saw several problems with the swap:
1. The track of the front wheels is to wide and forces use of negative offset wheels (like front wheel drive cars). 2. Rear spring perches had to be mover to center wheels. Not as big of problem as #1, but still an issue. 3. Depending on the year of the frame, the rear frame rails kick up, which forces you to raise the floor of your bed. 4. Your truck will not weigh enough to load the suspension of that donor frame, therefore you will have to change coils to get a descent ride. You will have better luck trying to use an S10 donor frame (extended cab LWB) since the track is similar (so is the weight of the truck) although you may still have to deal with #3. R Last edited by Hart_Rod; 12-12-2005 at 12:46 PM. |
Still drivin' a Rat Rod
Is that an S10 frame under your truck ROb?
How about some more pics of it? Looks great. ![]()
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Cantankerous Geezer
KCMongo has some good info on the S-10 swap. http://www.mongosgarage.com/S47/
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Suspension
It's got a mustang II (Heidt's crossmember) and parallel leafs from Chassis engineering.
r
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
More Pics
More pics............
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-12-2005 at 12:46 PM. |
nice truck!
Sweet ride. See you in Jax for Goodguys?
When's the show?
