Old 08-03-2002, 10:36 AM   #1
smitty62
smitty62's Avatar
Question Manual to power steering
OK--I'd like to convert my '68 from manual to power steering. Before I get in too deep, just what is involved besides getting a p/s box and pump? Will the box bolt on to my frame or do I need some sort of adapters? Thanks
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 08-03-2002, 11:28 AM   #2
slam33
slam33's Avatar
You need the box for these trucks, it bolts to the outside of the frame, the holes should be there. You need the pump, pump mounting bracket, pulley, the pulley off the crank, the hoses, and the pitman arm. Takes an hour or so to install.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-03-2002, 02:17 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
You also need the rag joint that joins the new power gear box to the intermediate shaft and the steering column. If I remember right, the manual gear box has a smaller shaft than the power box.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-03-2002, 03:24 PM   #4
smitty62
smitty62's Avatar
I've got a '70 box W/pitman arm coming and I have the pump, but I saw in one of the vendor catalogs a kit for this purpose ($89)!!! with the "necessary brackets, etc." What do you think that's all about?? Is this a bolt-on or not? Is there something I need to bolt the box to the frame other than the bolts? Thanks again
Smitty
Old 08-03-2002, 07:10 PM   #5
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Or if your mechanic has way too much stuff to do because of recent flooding (San Antonio, TX), and your dad won't let you touch your truck because the mechanic is gonna do it (gotta listen to your dad if he's been good about helping you out...)it'll take about three weeks.......
Don't forget to take a wedge out of the bumper bracket so it will make room for the box..the PS box is longer than the MS box....you can use a grinder or a torch....or maybe a sawzall with a metal blade.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
