Jostrans68
Eastwood spot welder
Any one use it for rocker install My body shop friend says its a great unit for this? heres pic.. price not bad
Quote:This tool produces spot welds very similar to those used when your car was built, and joins panels without the need to grind off weld beads. Spot welding is also fast, avoids distortion and confines heat. The spot weld gun attaches easily to your home arc welder set at 60 amps or less; simply connect the spot welder's cord to the electrode holder on your welder, ground as you normally would. Use the trigger to touch the electrode until a molten puddle of metal is formed. Then pull the trigger up to break the arc. Each electrode provides approx. 60-100 welds. Two
![]() former 67-72 now with a 96 silverado |
I have one and they do work well. All you need is a small stick welder for power.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
1969 Custom 30 wrecker
Cool! How much does it sell for?
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
I Love This Stuff!
How much and where can I get one??
JHickson6 |
Jostrans68
49.99 I have my Miller buzz box and just ordered on of these cant wait.
Jostrans68
http://www.eastwoodco.com/cgi-bin/sgsh0101.exe
this link should work its at the eastwoodco.com if it doesnt work go here and search spot welders........mine is on its way I will keep posted
Jostrans68
should be here today getting anxious LOL
Jostrans68
THE moment of truth
I have aligned the rockers and marked them tommorow I will break ou the new toy and see how it works. If it works as advertised the welds shoould almost look factory...Wish me luck......Jack
someday
![]() Join Date: Dec 2001
some info would be great i am thinking of getting one too!
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
Jostrans68
Works great straight up and down like picture proble is the rockers only have a small amount of perfect contact patch it burns through easy on the are that are flat it is great so I wirefed most of it.
