Old 07-09-2005, 10:46 PM   #1
71swb4x4
71swb4x4's Avatar
Rear bumper brackets different from pickups?
I am replacing my late model bumper with a sport bumper. The brackets I have are hitting the body mount. I pulled a bracket off my 4x4 Blazer and it has been clearanced so it doesn't hit the body mount. I assume this is the way Blazer brackets were correct? So I can just remove some material from my truck bumper brackets to make them fit?
I have attached a picture. The one off the Blazer is longer, but it looks like I will still have at least two bolt holes that match up with the frame on the shorter one. I don't want to remove as much material b/c you can see that the one broke at a bolt hole.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-09-2005, 11:52 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
2wd & 4wd bumper brackets are different. I'm not sure what is different, perhaps what you posted. I just know there are always separate listings for 4wd brackets.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-10-2005, 01:07 AM   #3
71swb4x4
71swb4x4's Avatar
I thought that was the front brackets. The front brackets are different because of the spring hangers.
Old 07-10-2005, 01:18 AM   #4
bouncytruck
SKINNY TIRES RULE!
Ahh, could be. I just remembered there was some that were different.
bouncytruck 1972 K5
Old 07-10-2005, 06:55 AM   #5
Is there a coil vs leaf difference in the rear?
Old 07-10-2005, 07:31 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Here is a pic of the ones I sold to a member earlier this year,
I did not need them because a 72 Blazer uses the end of the
frame as the inner brackets, and yes 2wd and 4wd front are
different also because of the spring hangers as mentioned
*Can't verify whether or not they are p/u or blazer, my PO
got alot of parts for "GQ" off of a rust free cali 67 cst p/u
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-10-2005, 11:54 AM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
This set of bumper brackets is for the SWB 2X4 and all 4X4. Note the length and reinforcement piece welded to the bracket.
Here is the LWB 2X4 and Coil Spring Rear set. Note they are shorter and no reinforcement. The outers are the same.
I would guess that the reinforcement would keep the bracket from braking like 71swb4x4's.
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-10-2005, 11:58 AM   #8
71swb4x4
71swb4x4's Avatar
Thanks for the pictures Wes. So should my 2wd Jimmy use the bottom ones? I think I am going to have to do some modifying to get these to work.
Old 07-10-2005, 12:50 PM   #9
Classic Heartbeat
Is the 2WD a leaf spring rear? If so, the (top) 4X4 ones will be what it needs. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 07-10-2005, 02:43 PM   #10
71swb4x4
71swb4x4's Avatar
It's coils. I had to trim a tiny amount from the flanged part, it was hitting the rear body mount. The body has been off before, and they used a couple of big washers, one is interfering with the bumper bracket, not a big deal. They are on now. Thanks for the help!!
Old 07-11-2005, 12:38 AM   #11
cheyenne10
cheyenne10's Avatar
Good pics Wes
Which brackets work on swb leaf spring 2x4?
Bob
cheyenne10 is offline   Reply With Quote
