Hard lines for bags
Has anyone run hardlines for bags? Any benefits/issues to doing this?
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
a buddy of mine ran copper lines on his caddy but I am not sure how safe that is
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
Copper gets brittle and will break. Stainless is possible but very expensive!
"but I am not sure how safe that is"??? Why do you say that?
I am installing it as we speak. From my understanding it is a good thing???
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) |
As you heat cycle through the copper it will get brittle and break. Copper is good to run for a shop air system because it is not getting jolted around and not getting temp changes from exhaust, engine heat. That is why on shop compressors they run a soft line to the copper from the pump!
its just $$$$$
I know several people that are running copper without any issues. It seems to work great. I guess only time will tell as to the reliability, but I know extensive metalworks has been using copper for quite a while now, and I havent heard any horror stories ................yet.
Trucker.
If you are gonna run stainless plan on spending between $500-800 for the line/fittings unless you have a sweet hookup.
What about aluminum? Stainless is nice, but flaring, etc. is harder because of the hardening.
#9 | |
Trucker.
Parker also makes non-flared fittings ... double ferrule (A-Lock fittings) and single ferrule (CPI fittings).
you could always go with the braided stainless also i had a few pieces made for my old dually looks sweet and gives you a leak free set up....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
boy that braided stuff adds up to. i know that braided fuel line wasnt cheap.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
#13 | |
yea your exactly right in looks. very clean. those fittings do rack it up expecially if you start getting away from straight fittings to something with a bend.
