08-01-2005, 09:53 PM | #1 |
Seasonal Poster
Question for people who know exhaust!
Hi all,
First off, I must say, my truck has never been all that loud. This is not to say that this is on purpose . The truck has had dual exhaust since the get go, first 1 7/8 now 2 1/4, and 3 different types of mufflers from glasspacks, to cheapy turbos, to now Flowmaster 40 series Delta flows. My beef is mostly with the sound at idle...it's just too quiet. The engine is quite mild, so far it's just a 350 4-bolt main, edel 1406 carb, HEI ignition, edel performer aluminum intake and corvette style ram horns. At idle is it very mellow, no lump at all and yes it has a wussy cam, but still...I have seen other cars with the Exact same setup that sound a lot lumpier at idle and I don't mean cam lumpy, just the sound of hearing every cylinder fire basically, mines just one steady mellow "flow" of sound. Can anyone tell me why this would be? I was thinking that it might be due to low compression maybe? Like being that each cylinder doesnt explode at strongly it's just mellow? I know this sounds kinda funny, but basically what I'm asking is what makes exhaust louder? (other than straight pipes) Because even with the old blown out glasspacks it was not really loud at all... you thoughts??? thanks
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
08-01-2005, 10:10 PM | #2 |
are you running headers or manifolds
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
08-01-2005, 10:13 PM | #3 |
exhaust
i think it may be because you're using the ramhorn manifolds. i've noticed on my trucks that everything that has cast iron manifolds has a more mellow less aggressive sound. on my '72 fleetside, i have a basically stock 283 with 305 heads and an "rv" cam with full length headers and 40 series flowmasters and this thing at idle sounds like it will eat your lunch. you may want to try some sort of header. my .02 worth.
68 SWB Stepside 72 Cheyenne 20 72 SWB Fleetside 72 Suburban 72 2wd Blazer Last edited by tripp; 08-01-2005 at 10:14 PM. |
08-01-2005, 10:16 PM | #4 |
Like a Rock!
Having a relatively mild duration on your cam will keep it quiet and 2.25" pipe is quiet as well. It's perfect for your cam but is really quiet in comparison to 2.5" pipe. Wher does your exhaust terminate?. The shorter the louder.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
08-01-2005, 10:22 PM | #5 |
big pipes, short distance, less bends, big tip, performance muffler, and free flowing exhaust manifold or headers all = more sound. also consider exit location for determining how loud, inside the cab with exhaust turning down at the rear is quieter than side pipes
08-01-2005, 10:54 PM | #6 |
Sounds like you have a finely tuned engine.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick" ~72 chev swb w/68 front clip "GM Millenium corvette yellow" I use and accept Paypal |
08-01-2005, 10:55 PM | #7 |
Seasonal Poster
I kind of thought it would be because of the manifolds, someday I do plan to get some sort of headers, but I want to wait until I can totally re-do the engine.
As far as exit location, it was exiting in front of the rear wheel until about a month ago, now it's behind. That, I know made a huge difference in the cab, I actually like that its quieter in there now, and extending the pipe changed the sound, but really the volume... Oh well, I thank you all for answering my question...someday it will be LOUD!
08-02-2005, 12:18 AM | #8 |
Your UncleBen
No tailpipes behind the mufflers....It will be loud and mean then
lata CHRIS
68 C10 shortbed -- Street/Strip |
08-02-2005, 11:19 AM | #9 | |
Seasonal Poster
This is true. The thing is, even when I had tailpipes in front of the rear tires it was super loud inside, but nothing crazy outside.
08-02-2005, 11:31 AM | #10 |
Im kinda partial to the mellow idle myself (yes, I have manifolds with a dual 2.25 pipes exiting behind the wheels)
It kinda sits there, peeerrrrrring. Then at a grean, it GROWLS and makes everyone look
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
08-02-2005, 11:57 AM | #11 |
compression ratio has a lot to do with it.
69 chevy short wide box project 70 GMC jimmy project |
08-02-2005, 12:12 PM | #12 |
Its Magically Delicious
is your truck a daily driver ??? attention is nice when your driving but not when its the fuzz
im running ramhorns with dual glasspacks that exit behind the rear wheel .. mines alittle loud but not at idle .. only when i press the go pedal .. but glasspacks dont give off the rumble that most people like ....
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
08-02-2005, 12:12 PM | #13 |
Just enjoy the peace and quiet! Horsepower doesnot have to be loud.
08-02-2005, 12:43 PM | #14 |
It is because you go the delta flow 40 series... there is a big diffence between the delta's and the regular two chamber flows... i mean BIG difference.
https://www.ebay.com/itm/29620574751...mis&media=COPY |
08-02-2005, 12:55 PM | #15 | |
Seasonal Poster
Damn, I should have grabbed those off of him when I had the chance...Although really, I do like the sound of mine, I just wish there was more of it So, does this mean that the delta flows are not 2 chambers?
08-02-2005, 02:59 PM | #16 |
Go Super 40's. I have them in my 3" system and the sound awesome.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-02-2005, 03:15 PM | #17 |
super 40's have the delta flow technology also.
08-02-2005, 03:39 PM | #18 | |
The LuvShack Garage
08-02-2005, 03:48 PM | #19 | |
Haha, thats what I have, and yes, its loud
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
08-02-2005, 03:48 PM | #20 | |
Seasonal Poster
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW Last edited by MandarinSixSeven; 08-02-2005 at 03:50 PM. |
08-02-2005, 03:51 PM | #21 | |
The LuvShack Garage
Wansn't useless, I was reafirming what was said about the differance in the flows, they do sound dramitically different, I'm sorry that you feel that way. My reply was based on the fact that I worked at a muffler shop for 2.5 years
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 08-02-2005 at 03:52 PM. |
08-02-2005, 03:53 PM | #22 |
Seasonal Poster
My Bad...
08-02-2005, 04:00 PM | #23 | |
haha I love flows just not a big fan on the delta flow technology. hey mandrin, i have a few videos of what mine sounds like for some reference. i can't post vidoes but i can email them to ya. i have 2.5" mandrel bent pipe with regular 40 series flows dumped after the muffler.
08-02-2005, 04:12 PM | #24 |
Whatever you do, don't get the small drag race 1 chamber mufflers that flowmaster makes. I have them on my 67 with a very similar motor. The exhaust dumps in front of the diff. and it's relatively quiet at idle but sounds like crap once you throttle it.
These were put on by the previous owner. Louder is not neccesarily any better. Those mufflers make it sound like the truck is one giant exhaust leak.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
08-02-2005, 04:19 PM | #25 | |
Seasonal Poster
Thanks for the tip, I'm glad you said that, because in my mind I keep thinking "gotta go louder, louder, LOUDER"...you just reminded me that an engine like mine with really loud exhaust, just sounds like a wussy v8 with a broken muffler. However, some more volume is needed in my opinion. I will take some videos after work and see what you guys think.
