08-01-2005, 11:40 AM | #1 |
Workaholic
part numbers needed
I purchased a 4 core radiator to replace the 3 core unit in my '91 Suburban. Does anyone have the GM part numbers for the correct bracket(s) and rubber mounting pads?
08-01-2005, 02:54 PM | #2 |
i dont remember or have the receipt, i just walked in and asked for the top mount and isolators for a 4 core, or say 91 1ton with 454.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
08-01-2005, 03:57 PM | #3 |
Workaholic
Yeah, guess I could do that but I was gonna try to order them online--hence my need for the part numbers.
08-01-2005, 04:42 PM | #4 |
ahhh sorry..
08-01-2005, 04:45 PM | #5 |
#14018600--- top mount, it still had the sticker on it..
08-01-2005, 05:27 PM | #6 |
Workaholic
Thanks a bunch. Only $8.31 at GM parts direct. Now if I can just find the numbers of the rubber pieces I'll be set.
08-01-2005, 06:45 PM | #7 |
i think you'll have to get a diff fan shroud too
1987 350 TBI lowered 5/7 |
08-02-2005, 08:45 AM | #8 | |
Workaholic
Prerunner--did you replace the shroud? |
08-02-2005, 09:52 AM | #9 |
well, i believe there's two different sized 4 core radiators......one is around 19" tall, and i'm thinkin the other one is 17"....so it may matter
08-02-2005, 11:12 AM | #10 |
Workaholic
I'll see how it fits.
Old one measures 28.375 x 19 x 1.625 New one measures 28.375 x 19.25 x 2.625 So, it's only a 1/4 inch taller. Hopefully I can get by with the current shroud for now. . . |
08-02-2005, 12:04 PM | #11 |
i am running with no shroud and with it reaching 100+ degs it only gets slightly warmer sitting in traffic, but hasnt come close to over heating. i will eventually either go with electric fans, modify current shroud or go with new correct shroud.. i did attempt to fit the shroud but decided to try it without... and it has done fine..
08-05-2005, 03:09 PM | #12 |
Workaholic
In case anyone else needs the numbers for the GM rubber cushions it is 6264100 (Qty 4).
Gonna install the radiator on Sunday. |
