Old 09-16-2005, 08:46 PM   #1
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
1978 Blazer 4wd to 2wd progress w/pics
Made some progress in the last few days. She starting to look a little different:
As of four days ago:
As of today:
milehightoyz is offline   Reply With Quote
Old 09-16-2005, 09:02 PM   #2
cochino12
It followed me home?
cochino12's Avatar
DAMN!!! thats low
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-16-2005, 09:14 PM   #3
bigblock73
yeller
bigblock73's Avatar
Thumbs up
Originally Posted by cochino12
DAMN!!! thats low
DAMN!!! That didn't take very long!
Looks good!
bigblock73 is offline   Reply With Quote
Old 09-16-2005, 09:33 PM   #4
82c10
needin' money
As of today:
does it have bags, if no how do you turn
82c10 is offline   Reply With Quote
Old 09-16-2005, 09:49 PM   #5
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
how did you get yours done so quick?......i just hit the point of engine installation......you did the frame swap didn't you.......good job.... i am slowly getting closer with mine
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 09-16-2005, 09:51 PM   #6
bigarmzz
bigarmzz's Avatar
thats gotta be bagged-with no front inner fenders
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 09-16-2005, 10:17 PM   #7
milehightoyz
yeah i did swap the entire frame out. that wasnt a whole lot of fun.
Actually no air yet, this is a static drop, prolly not the best riding drop ever, but static nonetheless.
3" spindles in front, 1 coil whacked off, 3.5" z,
flipped in the rear, 2" shackles, 2 leafs taken out. this is all temp set up, waiting on air and 4 link parts to come in. still need to finish fabbing trans mount. but frame is almost laid.
thought this was a cool shot of it slammed and the old 4x4 frame in the background.
Old 09-16-2005, 10:40 PM   #8
k72516
k72516's Avatar
Static??? Damn, that's loooooooooooooooooow. Watch out for ants and other monsterous type insects. Hope you get your bags soon, LoL
Go Fast - Be Loud
k72516 is offline   Reply With Quote
Old 09-16-2005, 10:52 PM   #9
82c10
needin' money
what is your turning radius then
Old 09-16-2005, 11:07 PM   #10
milehightoyz
i dont know yet, i dont have my steeing column hooked up. just by eyeballing, my guess i would be about 1.5" each way.
Old 09-16-2005, 11:15 PM   #11
82c10
needin' money
i was meaning how far would it take you to do a circle in it without screwin up the front fenders
Old 09-16-2005, 11:34 PM   #12
milehightoyz
i see, im not quite sure. im gonna have to get back to you on that one. i really have no idea.
Old 09-16-2005, 11:51 PM   #13
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Boy, you don't take long.
It looks good.
Got any close-up and backside pics of the Z'ed portion of the frame.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-17-2005, 12:20 AM   #14
milehightoyz
whats up boxrodz,
heres a couple of how I did the z:
Old 09-17-2005, 01:02 AM   #15
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Well, I can see why you removed the running boards...
I want a 2wd Blazer.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-17-2005, 03:00 PM   #16
sixty8c10
sixty8c10's Avatar
mine will be stock hieght when done, but i really like the way yours turned out....hmmm
Old 09-19-2005, 12:17 AM   #17
boxrodz
boxrodz's Avatar
whats up boxrodz,
Thanks for the close-ups. I've seen some where cut the front part of the frame just ahead of the steering gear. I'm not familar with the floor pan of Blazers, but after the 3 1/2" Z, do you think you need to raise/cut up the tunnel, firewall, ...?
boxRODz
Old 10-05-2005, 07:48 PM   #18
chevrunner21
i've got the 1985 k5 blazer and i was looking to slam it too but not quite as low as urs lol no money for bags and it needs to be my daily driver but i wanted to know if there was any sites telling me exactly what i needed to slam a 2wd fullsize blazer frame because i have no idea what parts i would need to buy to lower it.
chevrunner21 is offline   Reply With Quote
Old 10-05-2005, 08:30 PM   #19
74 shorty
Do you mean you made a 4x4 into 2wd. No offense but WHY?????
74 shorty is offline   Reply With Quote
Old 10-05-2005, 11:10 PM   #20
blazekraze
Is it possible to just join the front part of a 2wd frame(with suspension and all) to a 4x k5 and welding it/boxing it in? I've seen guys use Camaro/Monte Carlo front ends on older pick ups..
On a lighter note, if anyone has a 2wd rolling chassis for sale, I'm interested in one..
blazekraze is offline   Reply With Quote
Old 10-05-2005, 11:11 PM   #21
blazekraze
2wd k5's are real hard to find in my neck of the woods I don't know 'bout other parts..
Old 10-06-2005, 01:59 PM   #22
kevinr1970
I think if you cut the rivets off that hold the 4wd front "A" frame(?) in place you can then bolt on the 2wd "A" frame and suspension. Not exactly sure, but this is what I believe. Its been covered pretty good in at least the past year or so in the Blazer forum.
I'm not sure if you need to remove the front spring mounts or not? And I also think you have to replace the rear spring mounts as they have a different offset. Again, not exactly sure.
Oh, and you will have a different hump in the floor for the transfer case.
Best advise I got was to find a donor truck or idealy a Suburban - the Sub's have heavier brakes and such for a little better preformance. Take all necessary parts from the donor.
Which makes me wonder why Milehigh did the body swap and not just swap the suspension?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 10-06-2005, 02:01 PM   #23
kevinr1970
Oh yeah, 4wd's are literally a dime a dozen. 2wd's are a bit harder to come by.
I have a 2wd project in the for sale section......
2000 Tahoe Limited
Old 10-06-2005, 06:07 PM   #24
74 shorty
Hey, I have a two wheel drive truck swb and I want severely to trade for 4x4 in alright shape. There is nothing wrong with my truck but nobody will trade and around here everybody want 4wd. I just bought it because good deal. What did you do with 4wd chassis
Old 10-07-2005, 12:40 AM   #25
blazekraze
Wish you were closer to me, I'd buy it in a heartbeat, I have an uncle who drives an 18 wheeler and if he'd go up to Wash. I'd have him get it..
