08-24-2002, 01:20 PM | #1 |
And here is the same truck with 1 coil cut out of the front and I used a set of 2 inch blocks on the rear of a coil spring truck.
You can use 2 inch blocks on the rear of a coil spring truck but you must use longer u bolts and do a little bit of grinding to fit it up right. All in all It worked out good as I cant tell it rides any diffrent than before and it sits much much lower.
Life is good with a 6-71 supercharged 355 in a 72 camaro |
