Old 10-09-2005, 02:42 AM   #1
fleetside72
Question truck won't start
Hi Dudes!!,,i have an 85 Chev C-20...350 engine,,Automatic,,Lately i've had a hard time starting it...Now when i turn the key,,,Nothing...A freind of mine crossed the wires,,underneath,,by the starter,,and she wanted to go...I put on a rebuilt Starter/selonoid..and Still nothing...A freind said it's probably the Neutral Safety switch...I looked in a Chevyduty Catalog,,,they had the Neutral safety switch/Back-up light there....well i have Back-up lights...But Not a running truck...LOLOL...Im Really confounded...Help will be a plus here...THANKS GUYS!!!....GOD BLESS...Wikster :
fleetside72 is offline   Reply With Quote
Old 10-09-2005, 10:34 AM   #2
SSC's76
No No
SSC's76's Avatar
The engine wont start or the starter wont turn?
It sounds like the starter wont turn. There is an ignition switch on your steering column. It is what sends power to the starter. If the starter checks out and durring crank posistion on your key you have 0 volts to the small wire on the solenoid then most likey this switch is bad.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 10-09-2005, 01:03 PM   #3
squint
squint's Avatar
Does it turn over at all?.. does it make a clicking sound?? .
Do you have an aftermarket shifter or anything like that.?
squint is offline   Reply With Quote
Old 10-10-2005, 12:07 AM   #4
fleetside72
i turn the key,,,nothing,,,zero,,,zilch,,,good thing about it,is im saving gas on it by it not starting..LOLOL
Old 10-10-2005, 01:11 AM   #5
Jebb1978
Jebb1978's Avatar
There is a positive angle to almost every situation eh...
Jebb1978 is offline   Reply With Quote
Old 10-10-2005, 06:20 AM   #6
hobbz
hobbz's Avatar
are you sure that the battery isn't dead? there can be enough juice in it to light the lights, but not enough to turn the starter.
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 10-10-2005, 11:25 AM   #7
86 GMG
isnt there an inline fuse between the starter and the switch that runs down the bottom side of the engine??? im not sure also did you have the starter checked before you left the store to make sure it worked properlly i have bought some that were very weak (re-maned crap) just a few more suggestions and best of luck!
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 10-10-2005, 02:20 PM   #8
squint
squint's Avatar
Do your lights and everthing work when you try and start it?.
If so.. do they dim at all when you turn the key?..
I had a problem simular to yours.. I changed my starter and my truck would still not start.. it turned out i just drained out all the cranking amps out of my battery.. I tossed it on a charger for a hour or so and it fired right up..
Your battery can still have enough power to run all your electronics in the truck but not have enough remaining amps to start the truck..
just a though..
