Premium Level Member
Kickpanel Speaker Project*PICS*-updating all week till done!
Ok, as I noted in an earlier post, I started making my new speaker kickpanels as
mentioned on other post here in past. I bought one panel board at hardware store for about $5.00. Also bought a gallon of fiberglass resin for about $30, but you could get buy with a much smaller amount ![]() 1) Pic shows the panel cut, with raised "o" for speak, angled with various post length. ![]() Old T-shirt does the job..ruined with work on truck ![]() ![]() 2) In first pic, the "O" is already glued to t-shirt. Now to glue the shirt to frame of kickpanel. Buy a cheap $4.99 glue gun at HF..easy and cheap. ![]() Starting the glueing process. Work around, making sure it is smooth and tight( ![]() ![]() ![]() All done with Glue! Notice that I brought done the section that will have the vent lever secured to it so that there is no interference. You can see the glue line that makes this happen. ![]() Each day this week, I'll be adding to post as I progress. Goal is to finish for a Saturday installation!
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
Re: Kickpanel Speaker Project*PICS*-updating all week till done!
3) (the next pics are of the drivers side. I set the speaker lower to allow room for ebrake, vent lever and highbeam switch. )
Now, for a coat of resin. Based on my readings, i need one coat of pure resin, then two coats of resin with fiberglass mat cloth. This is just with the first coat of resin. ![]() Notice the crease on back side of enclosure. This is the slack t-shirt that I folded and set. Its hard now and nothing a little bondo won't cover, and its on the back side out of sight! ![]() Notice that I resined all the way over the ring to ensure good seal. I did this based on posted directions that I've read ![]() MORE TO COME TOMORROW
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 11-15-2005 at 12:23 AM. |
The LuvShack Garage
WOW
![]() Join Date: Jun 2002
Nice work, I may try this...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Hmn, I may have to do this...
how do you get the fiberglass to come in contact with the panel board? do you cut away at the fabric? thanks, bob
#7 | |
The trick would be to use porous fabric so the resin can soak through easily since it's fairly thick. This is my first time doing this also, so I'll try to provide the headaches that I encounter also...none yet though.
Looking good!
Ok, Tuesday evening process. This took me about 20 minutes to do, both passenger and driver side.
This is the passenger side. I gave it a first coat of resin only. ![]() Next is the driver side. This is the second coat and I used small pieces(4" by 6" or so) of fiberglass mat cloth. I just laid it down where I wanted it and with a paintbrush, thoroughly covered with resin until cloth was completely wet. ![]() This pic is with both driver and passenger kick panels. The angles are the same, but the driver side is set lower to accomodate the ebrake. The driver side now has the two coats, one resin(let dry) then resin and fiberglass mat. The passenger side has one coat of resin and is wet. ![]() Tomorrow night, I'll throw a third coat on the driver side, and a second on the passenger side. I should be ready to cover by Friday with material of choice. I have not decided on carpet or black vinyl..... ![]()
Project92 SWB stepside
Looks messy!! The resin, not you work!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 Last edited by phantom dually; 11-16-2005 at 12:00 AM. |
You are making it Look Way to easy!!
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Great pic's man!Thanks for the tutorial.
Keep it coming!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
No pics from last night, long day at work so too tired. I'll have more done tonight and pics
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 11-17-2005 at 10:00 AM. |
Jake, don't let us hurry you, take your time, you're doing a great job.
I appreciate the pics, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 11-17-2005 at 12:03 PM. |
#15 |
What size speaker will you be running?
Thanks for the "how to" ![]() |
#16 |
I picked up some 4" infinity speakers that were 40% off. They should sound nice. I'm off work today so after I get back from the DMV, I'll post more pics
#17 |
Good job. I've been into car audio very heavily since about 92'. Your work looks good and far exceeds many 1st time attempts that I've witnessed.
Next time try Speaker grill cloth to wrap the enclosure. It stretches much better. You then load the cloth only with resin. Once cured add the mat until you can stand on it. Once again great work. Robk |
#18 | |
![]() ![]() ![]() I just finished the passenger side today and second resin/mat coat on the driver side. Too much fun ![]() ![]() Correction to speakers size in earlier post, they are Infinity 5 1/4" speakers, not 4". ![]()
#19 |
The LuvShack Garage
Are you gonna be selling these? at discounted board members pricing of course
#20 |
Ok, as mentioned..i put the first mat/resin coat on the passenger side, and a second mat/resin coat on the drivers side. With the fibermat, the enclosure is VERY strong and solid.
So I set out in sun and dried pretty quick, at least enough to test fit ![]() Driver side with the soon to be speaker ![]() Now, in the truck, pedal and vent lever clear nicely ![]() ![]() A different perpective with my shoes ![]() ![]() Passenger side with speaker(test fit) ![]() In truck...why is you head turned sideways? ![]() ![]() One thing, they are not fully set in place, so nevermind the if they look off on edges, I just placed them easy for now. I am going to install them with some silicone glue once ready Tomorrow, final coats in early morning,sun, cloth/cover late in day
#21 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
This is something I have been wanting to do maybe I should add this to my very very long list of things to do..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#22 |
This does take some of the personal touch out of it, but you could buy some plastic kick panels and use them as a platform for the mold. You know...like the ones in the catelogs. If you are willing to cut into the metal of the kick panel you could recess the speaker just a bit and go a little more low pro on the size/depth of the mold.
Rob |
#23 | |
#24 |
Update- Well I've finished covering and installing the kick panels. Pics later today.
I lined the inside of the panels with Fatmat, then bought $5.00 worth of black material at the local craft store(took my girlfriend for support ![]() Installed my cd changer, Sirius unit, head unit(last week), and the panels. Sounds excellent. I think the fatmat i lined inside the kickpanels kills any kind of noise "twang" or vibrations. The tweeter is crisp and lows tight. ![]()
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 11-23-2005 at 01:06 PM. |
#25 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 11-23-2005 at 02:28 PM. |
