Old 02-06-2006, 02:36 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
Disappointing End to the Weekend
After having my truck in a friend's garage for over a week doing an engine swap, I thought I was finally ready to roll. BUT...on the way home I start seeing a trail of smoke out the back end and it got so bad I had to pull over. The good news is I don't think I'm burning oil but I definitely have a major oil leak somewhere; just can't figure out where. So, I crawled home and wound up missing almost the entire first quarter of the Super Bowl.
I'm about to give up on this damn thing...
Ole Blue 68 is offline   Reply With Quote
Old 02-06-2006, 02:46 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Disappointing End to the Weekend
That happened to me two years ago. My harmonic balancer seal went bad and the engine was slingin oil all over the passenger side exhaust. I had a huge smoke screen behind me, needless to say, that was fixed the next day! (kind of embarassing, ya know?)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-06-2006, 02:58 PM   #3
Ole Blue 68
Hell yeah, I had people honking their horns at me 'cause they thought I was on fire.
I'll have to get underneath it today to have a look see. It's was more on the passenger side but towards the back (at least that's where the oil was collecting). I had a ton of oil on the oil pan and that crossmember
Old 02-06-2006, 03:04 PM   #4
Dan72cst
Dan72cst's Avatar
Make sure you have a bolt in the old 55-57 chevy motor mount holes just forward of the fuel pump. That has burned me a couple times.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 02-06-2006, 04:14 PM   #5
AesC10s
Chevy truck addict
AesC10s's Avatar
This happened to me to about 6 months ago. Yes it is very embarassing.
AesC10s is offline   Reply With Quote
Old 02-06-2006, 04:29 PM   #6
Ole Blue 68
That's one I didn't think of Dan but it's an 010 block from the early 70's.
Old 02-07-2006, 09:21 PM   #7
68Stepbed
68Stepbed's Avatar
That doesn't matter. The material at the end of the hole is paper thin and will almost always leak because it is so easy to break. I put a bolt in my brand new crate engine just to be safe. Alot of oil can seep out of that hole.
If it seems to be from the back side, the first two places I would look is the valve cover gaskets and the intake gaskets.
What kind of oil pan and gasket do you have?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-08-2006, 06:59 PM   #8
MrC1
Dork For Days
MrC1's Avatar
Talking Re: Disappointing End to the Weekend
...and wound up missing almost the entire first quarter of the Super Bowl.
You didn't miss much!
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 02-09-2006, 10:36 AM   #9
Ole Blue 68
I did some checking under the truck and the internet on Tuesday and I think I got it narrowed down. We installed a Fel-Pro one piece oil pan gasket with Ultra Black. After doing some research, it turns out these things are supposed to be mounted DRY. So I'm thinking (and hoping) that's what the problem is. I guess it would help if I'd read the directions.
Old 02-09-2006, 03:13 PM   #10
Dan72cst
Dan72cst's Avatar
My motors were from the 70's too. GM still drilled and taped those holes in case you wanted to put them in a 55-57. I was just trying to describe which holes. Mine were drilled into the fuel pump push rod and leaked pretty good. Put a bolt in there and no more leakie
Old 02-09-2006, 03:37 PM   #11
OLDCHEV4X4
OLDCHEV4X4's Avatar
Power stearing hangs from those holes on the driver side.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-09-2006, 03:41 PM   #12
Dan72cst
Dan72cst's Avatar
I think the upper passenger side hole is the only one that hits any oil.
Old 02-09-2006, 04:10 PM   #13
Ole Blue 68
Hey thanks for the great info guys, this is one I never even thought about. The front looks pretty dry but I'm going to check these for bolts just in case.
Old 02-09-2006, 06:58 PM   #14
john
member #16
john's Avatar
If you put a bolt in the upper hole it has to be a short one or it will hit the fuel pump pushrod. John
john is offline   Reply With Quote
Old 02-09-2006, 09:24 PM   #15
Ole Blue 68
Short it is, thanks John.
Old 02-10-2006, 11:19 AM   #16
Ole Blue 68
If I'm going to try and remove the oil pan with the engine in, where should I jack it up at? The trans or can I jack it up from the balancer?
Old 02-10-2006, 12:42 PM   #17
OLDCHEV4X4
OLDCHEV4X4's Avatar
i made a cradle out of wood and jacked it up on the balancer with a bottle jack.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 02-10-2006, 01:01 PM   #18
Ole Blue 68
Thanks Old Chev!
Old 02-14-2006, 01:07 AM   #19
Dan72cst
Dan72cst's Avatar
Did you ever figure out where it was leaking?
Old 03-15-2006, 04:20 PM   #20
Ole Blue 68
Still working on this dang problem. I've gone through 3 different gaskets (one piece thick front seal, one piece thin front seal and a 4 piece kit) and the SOB still leaks at the back of the oil pan.
The oil pan is a brand new steel unit (not chrome) from Summit and it looks perfectly fine. We're gonna try another oil pan just to see but other than that, I'm at a loss for what the problem could be.
Anybody got any suggestions?
Old 03-15-2006, 04:32 PM   #21
67ChevyRedneck
Are you SURE it's comming out of the back of the pan? Or could it be the rear main seal?
Jesse James
Project "On a Dime"
Old 03-15-2006, 04:36 PM   #22
Ole Blue 68
Those are pretty much my two options as far as I know but it really looks like the pan. If this pan doesn't work, I'll replace out the seal as well.
Old 03-15-2006, 05:04 PM   #23
matthufham
rear main it sounds like.
matthufham is offline   Reply With Quote
Old 03-15-2006, 05:44 PM   #24
boogie67
boogie67's Avatar
Not to jack the thread but how do you fix the rear seal ?I think I have the same problem.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 03-15-2006, 06:04 PM   #25
67ChevyRedneck
Take out transmission, remove clutch/torque converter, remove flywheel, replace seal. I've never done it, but I think that's how it goes. I've heard it's a PIA when the motor is in the vehicle. Can someone please verify this?
Jesse James
Project "On a Dime"
