Old 03-12-2006, 11:32 PM   #1
ohmsc10
ohmsc10's Avatar
Rear cab mount question
Has anyone had a problem with breaking off the rear cab mount bolts? What does the bolt screw into? If the bolt would break, how could I fix it. I'm afraid that I will break off the bolts when I try to remove them. Thanks for any help.
ohmsc10 is offline   Reply With Quote
Old 03-12-2006, 11:42 PM   #2
qksilver
Re: Rear cab mount question
spray them with WD-40 or something a couple of times over a period of a day or to, then cross your fingers.
qksilver is offline   Reply With Quote
Old 03-13-2006, 05:37 AM   #3
al's71gmc
4 eyed fever
al's71gmc's Avatar
The rear cab mount bolt heads are under the fuel tank. Might be able to reach it without removing the tank, but since I was taking the cab off, I pulled the tank first.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 03-13-2006, 06:12 AM   #4
jc
jc's Avatar
there are 2 fixed nuts under the tank
usually the bolts loosen up without to much effort unless you have some bad rust issues in that area.
if you do have some bad rust in that imediate area you might want to move the gas tank out of the way and soak the threads
i just disasebled two very rusty trucks and i got em loose without much effort even though the shaft of the bolts were half rotted away.
ive broken front cab bolts before but never a problem in the rear
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 03-13-2006, 09:49 AM   #5
ohmsc10
ohmsc10's Avatar
Thanks for the help. I did not know you could get to the nuts. I will be spraying them with PB Blaster this morning.
