Old 04-11-2006, 10:55 AM   #1
Hook'em
Hook'em's Avatar
Removing Dealer ID Badge
I want to remove the dealer badge that is on the back of my Suburban (2004) but I don't want to mess up the paint. It appears to be affixed with some sort of tape strip. Any thoughts?
Hook'em
Hook'em is offline   Reply With Quote
Old 04-11-2006, 11:01 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Removing Dealer ID Badge
See if a hair dryer will soften the adhesive. Then you can clean it up with mineral spirits. But you will be able to see the unfaded paint where it was, unless you have white paint.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-11-2006, 11:19 AM   #3
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Heat is a good idea...Napa also makes a product called kleanz-ez that is really good @ removing the adhesive left behind. Its also good for bugs,tar,etc.
mblackburnjr is offline   Reply With Quote
Old 04-11-2006, 11:44 AM   #4
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Goo Gone (walmart with the cleaning supplies) will break down the adhesive, It may take a little more time, but it is a handy product to have around for cleaning up any sticky or waxy substance. Smells like lemons too
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 04-11-2006, 11:48 AM   #5
Chris H
72 C30 Trailer Queen
Chris H's Avatar
I usually take some heavy fishing string to use as a "saw" behind the emblem.
It will cut through the tape, then use some wd-40 and a hair dryer (or any of the previously mentioned adhesive removers). Finish it up with a very light polishing compound and a coat of wax. On a 2004, you shouldn't have any noticable fading?
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 04-11-2006, 03:40 PM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
I just work them loose by hand and clean up any adhesive residue with reducer.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
