04-21-2006, 07:18 PM | #1 |
Gas $3.12/gal - What have you done to improve MPG?
Since the gas prices took a jump overnight, thought this would be a good subject to see how people are helping their MPG....
I have tried a few things myself. I started at about 12MPG: - Tune up - gain 1MPG - New plugs - nothing - New K/N filter - nothing - Elec Fan - gain 1MPG So now I am up to 14MPG. Things not yet tried: - pcv filter - acetone additive - swap rear to a 3.08 - swap tranny to a 2004r - farting in gas tank PS:I have a 307v8 with a 2bb and a standard 3speed and 3.73 rear end.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
04-21-2006, 07:29 PM | #2 |
Re: Gas $3.12/gal - What have you done to improve MPG?
I have 66 primary jets 650 Cfm
K&N Accel Super coil HEI Max timing on the verge of detonation. 700R and 3:73's 28" tire Elec Fan No PCV I get 12MPG on super and 11 with regular gas.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-21-2006, 08:09 PM | #3 |
Putting a mostly stock roller cam 305 with the swirl port heads, (yep, all the wrong stuff) in our current project, headers, HEI, performer intake and edel 600 carb, and clutch fan. Vacuum and mecahnical advance will be fined tuned and will jet the carb down as much as is practical. 3.73 gears, OD manual trans and a little taller tires. Might put an air dam on the front if I can find one that will fit.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 04-21-2006 at 08:15 PM. |
04-21-2006, 08:20 PM | #4 |
man-o-man .... everyones talking it might hit $5.00 a gal. before its done! wow,thats gonna suck, guess i might have to buy a motorcycle...yea! a harley roadking! yea! it will suck much less then!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
04-21-2006, 08:58 PM | #5 |
put a fuel injected ls1 (5.3 style) in..... high gas prices rule!!!!
not really. |
04-21-2006, 09:15 PM | #6 |
Parked my 2500HD Quadcab after I put 57 dollars of gas in it and it had 1/4 of a tank. I am putting my 63 shortwide back on the road being it has a strait 6 with a 1 barrel holly. The 2500HD will only come out in case of emergency as long as the Gas Prices stays were they are. I am seriously thinking about looking into a Hydrogen Injection system for one of my Frankenstien Projects.
JRB |
04-21-2006, 10:43 PM | #7 |
Was getting around 15MPG with 3,07 gears.
Now gets about 14 with 3,73 gears. 355 c.i., 1406 Edelbrock 600CFM carb, TH400 trans. I went the wrong way didn't I? For gas mileage, anyway.
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside Last edited by GMan69; 04-21-2006 at 10:47 PM. |
04-21-2006, 10:51 PM | #8 |
Last year on my 04 siverado I put shorty edelbrock headers and k and n and I got 3gpm more on the freway and city 1gpm.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
04-21-2006, 11:00 PM | #9 |
I ride my bike into town and take the MAX train to work every day. Since January I have put less than 200 miles on my truck. Mostly to haul hay, dirt, and take my dirt bike to the trails.
04-21-2006, 11:03 PM | #10 |
Drillin oil on American Soil!
on my 92 with 210,000 i get about avg of 16 now that its warmer out, 14 in winter. all i have done is k&n, chip, lower thermostat, full length headers, and true dual exhaust. actually i achieved the best ever with that 1 month ago, 19 mpg going home for spring break, helped that there was no wind out, a first for north dakota!
Travis 70 Chevy c20 2wd 75 Chevy k10 4x4 parts truck 92 GMC Sierra c1500 2wd DD 99 Chevy Reg Cab Sht Box 1500 2wd 05 GMC Sierra Denali white |
04-22-2006, 12:10 AM | #11 |
i just changed my mind from a pontiac 400 to a 500 caddy for my project then on top of that i went from working within 5 miles from home to about 50, but just for a couple weeks. i've always been a$$ backwards
common sense isn't so common anymore |
04-22-2006, 12:11 AM | #12 |
On a slighty different note , the big three oil companies projected profits this year is a combined $80 billion . That's profit not sales .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
04-22-2006, 12:19 AM | #13 |
I just don't drive it much.
"You can take the man out of PA, but you can't take PA out of the man" |
04-22-2006, 12:21 AM | #14 |
Just filled the truck up today, cost a little over $50 for about 18 gallons. I have a stock 350 in my truck, with 194cc camel hump heads, stock 4bbl Quadrajet, stock cast iron intake, points ignition, TH400 auto, and 4.10 gears with a no-spin and new 33" tires. I'm not sure what kind of MPG I'm getting, but I have to fill the truck up about every 8 days and I drive it a lot. It's probably in the 10-11 MPG area. I'm guessing I better run some fuel system cleaner in the gas and install a HEI distributor.............
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
04-22-2006, 01:06 AM | #15 |
Traded in my Avalanche for an Aveo, no long distance parts runs in my 99 3/4 BB burb. Use my girl friends 2002 Impala when it won't fit in the Aveo and I don't need the burb. Amazing what fit's when the rear seat is folded down............shhh don't tell her, a 350 short block fits pretty good!
04-22-2006, 07:05 AM | #16 |
At 7 mpg I just don't drive it much anymore.
72 CHEYENNE 10 SUPER 468/400/3.73 |
04-22-2006, 08:35 AM | #17 |
Where's my beer?
I bought a new radiator for my V6 DD to get it back on the road so I'm not getting raped driving the truck every day.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
04-22-2006, 08:51 AM | #18 |
Im buying an old 87 honda accord hatchback its cheep the air conditioning works and it gets at least 20 plus miles to the gallon, and I can burn the cheap gas... O I forgot there is no cheep gas.....it sucks but you have to do what have to do....
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay |
04-22-2006, 09:11 AM | #19 |
Damn I'm broke
I drive a 96 neon to work and back - just a beater car with cold a/c I picked up from a friend for 1k, it had 170k miles on it when I bought it, now it has just toppled 200k, I get 28mpg in it, not bad for 1k....drive it until it blows plus the insurance is cheap....I even parked my IndyRam since it only gets 16mpg...on the weekends I take out my pride and joy, the 67...I am running a 510 lift cam in a 93' motor in it, it only likes super....I wish I could afford to drive it everyday but it doesn't have A/C yet....Texas is starting to heat up....
[B]67 Chevy truck stepside small back window 96 Dodge Indyram 74 Dart Sport 96 Neon |
04-22-2006, 09:54 AM | #20 | |
I put $24.82 in the tank 3 days ago. The last time I stopped for gas was 12/9/05. My daily driver gets 36-41mpg depending on how I drive. That car is a 94 Escort with 248,xxx miles on it - all driven by me. If you guys are looking for a cheap daily driver, and like me only buy American, look at a 94 or 95 Escort 5-speed. My AC still works. My winter mileage is 32-34. Summer is 36-41. I bought mine brand new for $10,353. Now you can get one with 100,000+ on the clock for $500-$1500. If you change the oil regularily and put a new timing belt and water pump on every 70k, you should easily get 200,000 out of the car. PLUS you'll be saving wear and tear on your truck. I'm sorry to say it guys but very few of these trucks should be daily drivers. If you aren't getting 20+ mpg in your daily driver you should really re-think what you drive every day. My Escort is getting tired and will soon have to be replaced. I won't buy anything that isn't American and doesn't have an EPA 30 on the window sticker.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-22-2006, 10:11 AM | #21 |
Marketing,ok we've sold too many big trucks(gas eaters) not selling any little cars so let's raise gas up so,everyone will quit buying the big trucks,and start buying the little cars,then oh were not selling enough gas(gas company) were loosing money,let's lower the gas prices so we'll sell more gas,after they've sold alot of little cars,And then it start's all over again.What's the world coming too,I know It's coming to an END ,SO EVERYBODY BETTER BE GETTIN READY.I AM,RANDY
1964 BBC 402 4x4 |
04-22-2006, 01:03 PM | #22 |
I junked the POS gas engine and went with a Diesel.............
But I haven't got the driveshaft back that the Diesel tore up, or I'd be driving it.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
04-22-2006, 01:49 PM | #23 |
I don't drive half as much as I used to. I live 6 miles from work so I don't mind driving the Z71 and I can't wait to get the '67 going again. But if I lived any further away, I'd have to consider a 4 cylinder S10 or maybe even a ranger I don't know whats wrong with me, I'm just not happy driving a car.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-22-2006, 02:48 PM | #24 |
im gettin 10 mpg on 93 in my '69 and its the only runnin truck i have. i've been tryin to drive less, get more gas money from my buddies, and mow more yards. high gas prices sucks. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
04-22-2006, 03:22 PM | #25 |
Well as crazy as this sounds, I got out the 2000 Corvette Convertible out because it gets around 28 mpg if you keep your foot out of it. My Chevrolet extd. cab that my dealership provides only gets 18mpg and my 2000 powersmoke diesel gets only 13 mpg with 35" tires. I work 87 miles away one way so it was killing me on fuel. I also now rent an apartment out of town with one of my co-workers and it is still killing me driving back and forth to work and then home on the weekends. Do not know what else to do. Looking in to buying a 500.00 dollar little 2 door civic.
