Old 04-24-2006, 09:52 PM   #1
71chevytruckguy
71chevytruckguy's Avatar
posi in the rain
im trying to talk me dad in letting me get a posi rearend for my '69 but he sayes that he has talked to some people and says they are not safe in the rain becuase the don't "unlock" around turns. i was wondering what some of yall that had a posi rearend in a daily driver thought about them and if any if the things he heard was true. thanks yall. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-24-2006, 10:19 PM   #2
Paul M
Junior Member
Paul M's Avatar
Re: posi in the rain
posi's in the rain when you jump on it or take off briskly will spin both..and if your turning..will spin you around ina circle...as i did once in the middle of an intersection...can be ok once you are used to it and you use care during the rains/wet road conditions
Paul M is offline   Reply With Quote
Old 04-24-2006, 10:42 PM   #3
1969 GMC
1969 GMC's Avatar
i think any RWD vehicle can spin you around if you gun it in a turn and you arent watching.
i'm guessing your dad only wants you to burn one tire off at a time. he is a smart guy, trying to save you money. you should thank him
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-24-2006, 10:52 PM   #4
Paul M
Junior Member
Paul M's Avatar
yep..which younger drivers tend to have a heavy foot and can be distracted easily..why dad is thinking ahead and saying not this time with a truck with a lighter back end...
Old 04-25-2006, 08:32 AM   #5
mplex2000
mplex2000's Avatar
Get a locker, they unlock around corners
mplex2000 is offline   Reply With Quote
Old 04-25-2006, 08:45 AM   #6
Medicanman71
Medicanman71's Avatar
You can get an open diff to hook up posi if you hit the gas when it's wet out so either way that's not too important as far as that goes.
A kid back in hs thought he had it down pat as far as counter steering and fishtailing around the parking lot went when it was wet. They were going around and around till the point everyone hanging around really lost interest.... then you know it, out of no place....... WHACK
Hung a bit too wide while he had too much speed around one corner and slammed the bed into a cage guarding an a/c unit for such a reason. He has a wooden stake bed and that thing blew up, splintered everyplace.
you just have to be carefull and not get too cocky.
As said, why not just get a locker etc.
Medicanman71 is offline   Reply With Quote
Old 04-25-2006, 04:00 PM   #7
71chevytruckguy
i've already learned my lesson with truck once the same rear end in the rain. first day i had it runnin after a I6 to V8 swap. got one the gas too hard gettin on to me highway and the back end broke lose when i hit second with the 3 speed i used to have in there. hit the back of an 18 wheeler. put i a 2ft dent in the driver door and totaled the cab. had to put a new can and door on there myself. was truckless for 6 months cuase of my dumbass. so i've learned my lesson.
the reason i want it posi so i can try to get this thing to hook up at the local drap strip, not to be a dumbass. took it there for the first time last weekend but if spun there 1st and 1/2 thru 2nd.
reason for posi over a locker is im really good friends with the onwer of the local junkyard and he has a 3.73 posi rear i can probably get him to trade for the 3.43 rear that in the truck know. im on a real tight budget.
i do 99% of the work on my trucks by myself, spend my money that i've earned working to build them, and pay for gas. so i kinda ticks me off when he tries to tell what i can and can't do to my trucks.
here's a pic of the '69 after and wrecked it. and the new motor i put in it. chris.
Old 04-25-2006, 04:15 PM   #8
82c10
needin' money
it's your money get the posi
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 04-25-2006, 04:19 PM   #9
Chevrolet4x4s
Chevrolet4x4s's Avatar
Go for the posi and be careful.BTW did you get your truck repared if so can we see some pics?
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 04-25-2006, 04:33 PM   #10
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I used to pop the clutch and hammer the throttle when making right hand turns in the rain just to see how far I could spin the right rear tire. That was with the open differential and it always went straight as an arrow.
I knew what was possible with a limited slip in the rain and the same day I picked up the truck after having an Auburn limited slip put in it was raining. Naturally, the first right turn I made I popped the clutch and hammered the throttle. Immediately the axle went live and swung into the on-coming lane right at a car. I barely got out of it before the car hit me or should I say before I hit it?
Needless to say, that was the end of my horsing aroung in the rain. The limited slip does help when pulling away from a stop light (in a straight line) when it's raining. I don't think they are dangerous if you drive normally (I mean driving like normal people. Back then my normal driving was ) instead of like a morron when it's raining.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 04-25-2006, 04:37 PM   #11
71chevytruckguy
was just gettin ready to post some, had to go take a pic. first is of the truck how is looks now and second is the motor installed. its a work in progress. chris.
Old 04-25-2006, 04:50 PM   #12
crazy longhorn
Fabricate till you "puke"
I dont drive my longhorn in the rain or snow, but will say that a healthy dose of throttle around the corner (with 4.10's & an Eaton posi), will make that old truck do doughnuts on DRY pavement listen to your Dad.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-25-2006, 10:35 PM   #13
68350
68350's Avatar
The 68 GMC I drove to school my 10th grade year and half of this year had a 3.08 posi. It was fine until snow hit, then it was scary and really made me alert. If I didn't watch and pay attention, it would hit ice and start sliding, espicially after about 40 mph. Rain wasn't bad for me, you just can't goose it around corners and you have to watch the straight aways from a dead stop. I would say go for it because it really helps for burnouts and if you get into any slop or anything.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 04-26-2006, 02:30 AM   #14
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
I remember my 442 cutlass with a posi & a shift kit . It would spin the tires & chirp em on dry pavement so you know what is was like in the rain. I stopped at an intersection in the rain , took a left turn and before I knew it it looked like i took a right turn. Be careful when making turns especially when WET.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 04-26-2006, 10:13 AM   #15
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
An accident like you had will make you grow up quick. I have a posi 3.73 in my truck. Two in fact. I've never had trouble at an intersection in the rain. I also drive my truck like an old grandma when I'm in town.
I already spent my time hot rodding my old chevelle. 8 tickets and two accidents later, I'm not in a hurry, and enjoy my vehicles.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 04-26-2006, 11:18 AM   #16
shortymac83
hmm...
shortymac83's Avatar
My Delta slides all over the place WITHOUT a posi. It's just a matter of driving. If you want it to slide out, it doesn't matter what you have, it'll slide out. If you want it to stay put, don't hammer a car through the turns.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 04-26-2006, 03:57 PM   #17
71chevytruckguy
yes i did and scared the pants outta me. plus the feeling of knowin that your hard work, sweet, and blood have been wasted due to your stupidy is a horrible feeling. the part i knowin that you could have prevented just by takin it easy. today is the first time i've had it back on the highway in the rain since it totaled it and i was pretty nervous goin by the same stop a wrecked at. but i was very easy on it and was shiftin at 2000rpm, right before where the engine to starts to make some real power, and i made it there and back in one piece
from i hearin so far, sounds like if you say off of it, take it easy, and don't hammer it around turns, you'll be fine. but keep the reply's comin. my dad can be as stubborn as i can about these things. thanks yall. chris.
Old 06-01-2006, 05:04 PM   #18
sbc383rulz
sbc383rulz's Avatar
Cool Re: posi in the rain
i got a posi 4.10 with a 383/375 4 speed and it can be alot of fun in the rain just gotta drive like you paid $500,000 for it and youll be fine burnout are great with a posi makes lots of noise and rubber i get 3rd gear rubber in the rain at 55 if i hammer it so its all in how ya drive it
sbc383rulz is offline   Reply With Quote
Old 06-01-2006, 05:37 PM   #19
boraxman
Keepin an eye out
boraxman's Avatar
It just dont seem right having a one legger. Posi was the first thing I did to my Chevy.
My Toyota Tacoma got a ARB air locker.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-01-2006, 05:57 PM   #20
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
My 2003 Silverado has a 3.73 posi rear. Not much different than the 68 with a 3.73 posi rear end. Except that the 2003 Silverado has a supercharger, so it will light the tires just by thinking about it!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-01-2006, 07:00 PM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I can still recall (just barely! ) being young, and having several cars (up to a 375-hp BB El Camino, and two strong Corvettes) with posi units, and being from NW Oregon, I have driven in the wet a lot. I never got into any trouble (at least not the kind we're talking about here), and you have already seen what can happen if you get a bit careless. In over 40 years, I have never seen or experienced any problem caused by running a posi.
I definitely recommend getting the posi, and I firmly believe the plusses far outweigh any possible drawbacks. Of course, your Dad has the final say, but fwiw, let him know that I am a conservative guy, have raised 3 kids, and am a firm believer in safety and responsibility. Good luck!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 06-01-2006, 08:48 PM   #22
Chevrolet4x4s
Posis are great and really help with traction issues...also did you try the slicks?
Shane
Member#20327
Old 06-02-2006, 12:09 AM   #23
jimfulco
Find a big empty parking lot to use for practice on a rainy day. Take it out & see what it does under wet conditions, and you'll soon get a feel for it.
jimfulco is offline   Reply With Quote
Old 06-02-2006, 01:12 PM   #24
71cadc10
71cadc10's Avatar
Chris,
Good to see you got your motor done and in, congrats!
I'd go for the posi also if you want to do much drag strip action. Is there a 1/4 mile strip down there or just 1/8?
later,
Andy
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 06-02-2006, 01:24 PM   #25
mrein3
mrein3's Avatar
Those of us who grew up driving rear wheel drive cars in the snow belt think its real cute hearing stories about how you southerners can't drive a car or truck around a corner in the rain.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
