05-20-2006, 07:38 PM | #1 |
Never Done?
The elves showed up - Finally met my Feb. goal!
Well, it has been a busy weekend so far.
Started with this last night: Got it to this point early this morning: And right now it looks like this: My goal for February was to have the thing rolling... and I finally made it! Going to try to get the steering linkage all cleaned up in the next couple days and hopefully get some outside shots of the whole thing aired out. Then off comes the bed, and the rear suspension comes apart. Maybe the end isn't as near as it seemed At any rate, I'm too stoked to keep this to myself. |
05-20-2006, 08:35 PM | #2 |
A guy with a truck
Re: The elves showed up - Finally met my Feb. goal!
Lookin good!
- Are you running drop spindles? - What bags you runnin? - How deep are your cups? Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-20-2006, 08:58 PM | #3 |
Never Done?
Thanks! Here's answers to your questions:
ECE 2 1/2" dropped spindles Firestone 2600 224c bags Cups are AirRide Tech. pieces, 1 5/8" tall (not sure if they're modified or not, bought them used) Tires are 275/60/15... for now. Oh, and the measurement is somewhat misleading (before I get called out on this), the back of the truck is still up on jack stands, so it is angled down in these shots. Accurate measurement coming soon. Last edited by Alvin; 05-20-2006 at 09:00 PM. |
05-20-2006, 10:42 PM | #4 |
Questionable
Well, damnit, you got me jealous.
i can't wait till i get to rebuild the greaseball of a frontend my truck has got!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-21-2006, 04:47 AM | #5 |
MEMBER
Alvin.. You obviously know what you are doin. But the first time I did a ground up I to painted my frame flat black but the problem is it doesent seal and it oil stains. I see alot of guys do there firewalls flat black. It looks great for about two months I always use high gloss on everything now. For all I know you might be painting this thing any color as early in the build as you are I just thought I would make a suggestion..Just in case...Hell it might be powder coated cant really tell..I stopped powder coating most of my parts because it nicks and scratches and you end up touchin it up with paint any way....Beautifull build so far. Keep the pics coming. After seeing your truck tonight I turned off the computer and the tv and went out in the garage for a couple of hours....
86 sub 4wd, 1 ton, duallie, big block th475 72 c10 short fleet, pro street 72 K/5 blazer,2x4 almost stock 72 3/4 ton sub 4x4 61 morris minor pickup, chevy 4.3 v6 03 escalade, 24" momo's wifes 96 2wd 2door tahoe 67 2wd suburban 72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo. Last edited by local13hutch; 05-21-2006 at 04:48 AM. |
05-21-2006, 07:59 AM | #6 |
Never Done?
Yeah, the flat black is what I would like to have, but like you said it just isn't practical. With how long it has taken me to get this far, I just want to get it together and drive it for a little while. Once I get everything working how I want, It will most likely come apart again and get done "right". Thankfully it's not gonna be a show truck by any measure, so as long as it functions I'm happy. Thanks for the tip!
05-21-2006, 08:56 AM | #7 |
Looking good on what you have done Alvin!
06-06-2006, 01:04 PM | #8 |
Hot Rods For Life
Awesome!
06-06-2006, 01:20 PM | #9 |
Outlandish Trends - FL
Alvin, looking great! Thanks for the info on the lower cups, I've heard mixed opinions on those, some running cups, and some running just lower plates. I think I can use the lower cups as you have. Pictures speak volumes!
-Bret 67 short-fleet sold! |
06-06-2006, 02:36 PM | #10 |
Never Done?
Thanks guys. Things slowed down the last couple weeks as I had some chores to do around the house , and I was pretty busy trying to figure out my next move on the truck.
All new steering components should be at my house when I get home today. I was going to just degrease all my old stuff, but when I got it apart I couldn't stand the thought of putting the old stuff back on. Then it's on to ordering a wiring harness, fuel line stuff, rest of the air ride parts, a SECOND box of brake lines... I think you get the idea. It seems very close to being "together", but when I look at my parts list I'm still over $1k away . |
06-06-2006, 04:09 PM | #11 |
Can you take some pics of how you ran your front airlines? What fittings did you use and where did you get them?
Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-06-2006, 04:50 PM | #12 |
The LuvShack Garage
Nice progress
06-06-2006, 07:06 PM | #13 | |
Never Done?
06-06-2006, 08:02 PM | #14 |
Nice work Alvin.
06-06-2006, 09:24 PM | #15 |
Adam, the toughest problems are never solved in leaps but in tiny steps--kind of like Tim Conway~~~~. Keep chipping away and the truck will come together---just like you want it too. Don't rush it or you will always regret it!
Looking good!!!!!!!!!!!!!!!!!!!Nice frame!hehehehe |
06-06-2006, 09:34 PM | #16 |
Never Done?
Well I got a little bit more done today. My box 'o parts was waiting on the stoop when I got home from work. Ordered everything through Advance Auto Parts online and I gotta say it went pretty well. There's really nothing like a stack of new parts just waiting to go on.
I cleaned up the tie rod ends and started masking them off for paint. Trying to mask off the grease fitting holes had me scrounging around the garage when it hit me... EAR PLUGS! So I grabbed a couple old pairs of ear plugs (I knew I held onto them for a reason!) and stuck 'em in the holes. Finally got out the ECE quick-ratio steering box I bought years ago and bolted it up. So once this stuff is dry, I'll be putting the steering linkage together and hopefully be on my way to the rear suspension. |
06-06-2006, 10:43 PM | #17 |
Are you gonna be runnin a 6 cylinder in there? the towers?
06-07-2006, 07:54 AM | #18 | |
Never Done?
06-07-2006, 08:28 AM | #19 |
Ear Plugs ---dam, forgot to take them out. No wonder everything has been muffleled for a while!!
My short bed truck is being dropped way down too but with a different process--just started converting it to 5 lug and am using 15" rallies with a 245x60 tire on it! Now if I just keep the air pressure to around 20lbs--hehehe. |
06-07-2006, 08:46 AM | #20 | |
Never Done?
06-07-2006, 09:25 AM | #21 |
250 V-6 Club
looks great. keep the pics coming.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523 Never ask a stupid question unless you want a stupid answer . |
06-07-2006, 10:04 AM | #22 |
That will be a sweet ride when you get done. Keep at it!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
06-07-2006, 08:23 PM | #23 |
Never Done?
Thanks for all the kind words guys. Definitely gives me the desire to keep plugging away on this thing. I ordered the ECE rear crossmember today so it will be ready to go whenever I get the bed off this thing (approx. a week?).
Tonight I got the steering linkage all together. Of course it still needs a good bit of adjustment, but at least it's together! This weekend (if not sooner) I'll be rolling it out of the garage and getting measurements together for next weeks part ordering extravaganza! Other pics: How the whole thing looks right now | Wiring harness from MDC (thanks!). |
06-09-2006, 08:39 AM | #24 |
Never Done?
Yesterday I was able to air up the front suspension and pull it out of the garage. Seems like I may have lucked out on plumbing the air lines, couldn't really locate a leak (other than one of the schrader valves I had on there). We'll see what it looks like this afternoon. Also got the swaybar on, but didn't get any pics of that. At any rate, here are some pics and a few videos
Video #1 Video #2 Video #3 I still need to upload the pics...and here they are: Click here to see the rest, latest pics are at the bottom. Last edited by Alvin; 06-09-2006 at 10:47 AM. |
06-09-2006, 10:16 AM | #25 |
PROJECT 7DEUCE
Very nice work wish mine was comming along as fast as yours is mine always seems to get slowed by house projects...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
