A/C compressor cycling on and off
Hey guys, the A/C compressor in my truck keeps cycling on and off, and this is when its in the "off" position!
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Insert Witty Text Here
Re: A/C compressor cycling on and off
Does it cycle on and off when the A/C is turned on? If so, you are low on refrigerant.
Here is the part where I make a wild guess... ![]() Slonaker |
Yes, it will cycle on and off with the A/C on too. I have to keep it on vent for it to shut off. I'm going to have the system leak tested and recharged next week. Is the dash control a hard item to replace?
Truck junkie
![]() Join Date: May 2006
Most ac systems will cause the compressor to cycle on and off even if the ac isn't on when the charge gets low.
#5 | |
![]() BTW, I bought the part from an auto parts store that sells AC Delco parts. I think it was about $50. Getting stuff through the parts store is usually a lot cheaper than the dealer, though I did not compare the prices this time. Slonaker |
Parts and more parts
The hardest thing about changing out the dash control is getting the dash apart to be able to pull it out far enough to remove the vacuum fittings and electrical connections. After that everything is easy.
mine was low and it cycled until it broke the face off i put a new face on it and went to town again and charged it up
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
#8 | |
Stepsides RULE
I'd suggest checking the rest of the system IF your dash bezel is in poor shape, or else you might end up dropping money on a HVAC control AND a dash bezel. Good luck ![]()
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
Ok, thanks for the help everybody. I'll let you know how it goes.
I have a shop manual for a '73 and it says that the compressor should be on in all positions except off, vent and heat. The low pressure switch is in series with the compressor so if it is low on freon it will not come on or it will cycle.
