its all about the +6 inches
And you thought the PO of your truck was a tool, (look at this dude's truck)
I found this on another 67 - 72 forum I frequent.
At first, I saw this one, and said... well, it looks typical, the radio hole is big enough to put a TV in, but I've seen worse. So then i saw this one.... I thought good lord, this thing is hacked! Remember guys... less is more. Then the kicker, this one should win the poor guy some kind of an award... like a new cab or something. Just look at this crap! Just becouse you CAN do it, doesn't mean you SHOULD do it. |
Who's got steelies?
![]() Join Date: Feb 2006
Re: And you thought the PO of your truck was a tool, (look at this dude's truck)
I'd say that truck was plugged in.
I can't believe they molested a dash to install Radiocrap junk.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Looks like they were building an airplane cockpit.
10/30/19
Thats pretty Gucci.
Fight the good fight, finish the race, keep the faith |
ratrod, i was thinking the same thing.
Truck junkie
![]() Join Date: May 2006
Thats freakin hilarious...looks like an airplane cockpit with crappy radio gear. I just had to rewire a 69 firebird that was almost that bad...It had like 12 switches where the radio and heater controls were supposed to be with all the battery power coming in on red #10 wires straight from the battery, you had to flip three switches push the brake down and push a silver button under the dash to start it. I ended up building most of the dash harness from the firewall to the column, lightswitch,heater controls,guage cluster plug etc. all over again. I'm glad I don't have to fix that mess. usually a guy will bring crap like that to me and say he wants all of that garbage to work.
Holy crap!! And I thought mine was bad. I recently bought one that the PO not only cut two circular holes next to the ashtray for guages but also had put enough radios in the stock location that the hole was too big. So what did they do then? Tried to open up the ashtray hole large enough to fit it in there. When they realized the two oversized holes would then become one huge hole before any radio would fit, they gave up. They then put a large plexiglass plate over the hole mess (much like you see there) and then mounted the radio to the plexiglass and put the ass of the radio through the hole in the dash. I wont even get into the 4 different transmission tunnel repairs (for different shifters), the sunroof, the CB antenna out the back of the cab or how they bent the back cab corners under (by the frame) for the exhaust to run along the outside of the frame rails....
What really sucks is that it's a rust-free cab!! ![]() ![]()
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Truck junkie
^^^^ ouch! figures.
Keep On Truckin'
Holy crap!!! Penny, this is Sky King I'm coming in for a landing
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 06-05-2006 at 08:42 PM. |
![]() "Negative Ghost Rider...the pattern is full"
I have an uncle that worked for Boeing as a aircraft electrican, his 70 Bronco looked like that, CB, scanner, weatherband radios and more switches & fuses that you couls count.
![]() Join Date: Apr 2005
OMFG!
1978 Dodge Omni |
#13 | |
The LuvShack Garage
And the floor and rockers don't even look rusted out. What a waste.
1978 Dodge Omni |
#15 |
Man I'm diggin that steering wheel... cover? Thats like far out space ODDITY stuff dude! Where can I get some,, yellow tape to wrap mine with?
I hope who ever gets ahold of that thing cleans the roachs out of the ash tray. But Wait! There is no freekin ash tray! Check the floor board ![]() Last edited by TugOwar; 06-05-2006 at 09:00 PM. |
#16 |
must've quit before installing the flux capacitor??
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
#17 | |
#18 |
71 GMC 454/TH400
"We need clearance clarance" "Roger rodger" I think that truck had the ultra rare moon rover package. How ever I have seen simular things done to trucks when I was in the fire truck buisness.........
"The bigger you are the harder you fall, the farther you walk the longer you crawl." |
#19 |
No doubt those are HOT aircraft switches, fuse holders and other crap randomly installed with no rhyme or reason. Just buy a airplane if that's what you want. What a frickin' mess!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#20 |
Outlandish Trends - FL
Maybe he's just trying to build a time traveler. Hey, it's cooler than a phone booth!
-Bret 67 short-fleet sold! |
#21 | |
#22 |
I can see rigging up a toggle switch or two, to by-pass an old burnt-out switch, or run a new accessory, but there is no way that anyone would ever need all those! About the radio opening...it's better than some I've seen, at least they didn't bend back the metal with pliers, and force-fit the radio in there.
![]() Last edited by Sheverlay; 06-05-2006 at 10:41 PM. |
#23 |
Happy Camper
Too close for missles, switching to guns
RIP El Jay! Love you brother! |
#24 |
collector of vintage rust
Well at least he labled a few switches w/ masking tape for those who've yet to acquire their pilot's license.....lol
#25 | |
Son Of Gravel Man
If it is supposta be a airplane where is the pin up girl pic?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
