Old 06-06-2006, 12:21 AM   #1
bagged74
its just $$$$$
bagged74's Avatar
72 2wd blazer build
This is my thread to cover the build of my 72 2wd blazer. I purchased this Blazer from a board member in the Dallas area early this year. It was in a general state of disrepair. It hadn't been driven in some time. The interior was non-existent, and what was there was not correct for the truck.
I was happy to get it none the less.
heres what she looked like when I picked her up
bagged74 is offline   Reply With Quote
Old 06-06-2006, 12:26 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: 72 2wd blazer build
I got it roadworthy and started driving in a little. I put on a new set of tires and did some minor mechanical repair. Then I decided it was time for an altitude adjustment. I got some 3" drop spindles and cut a coil off the front springs. The guy that I bought the blazer from gave me some drop springs for the rear so I put those in also.
Old 06-06-2006, 12:29 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
Of course after I got it lowered I had to get some bling on there. I got a good deal on some 20" Coys Rodders and Falken tires. The fit is not perfect, but the looked better than the rally wheels that were on it before.
I also added a flushmount fuel filler door because I cant stand the look of the gas cap on the quarter panel.
Old 06-06-2006, 12:35 AM   #4
bagged74
its just $$$$$
bagged74's Avatar
The truck was originally a low option 6cyl/3 spd truck. Somewhere along the line it had been converted to a 350/4spd. The 350 runs good, but the Saginaw 4spd is a little noisy. I guess that doesnt matter though since it is now sitting in the shop floor. This is what she looked liek under the hood when I got it.
Old 06-06-2006, 12:39 AM   #5
bagged74
its just $$$$$
bagged74's Avatar
Soon after i got to this point I decided to tear it down to fix the rockers and patch a couple of places in the floor. Well this got a little out of hand and the body is now on the rotisserie. I have sandblasted the whole underside of the tub. I also sandblasted the windshield frame and dash for good measure. I put some epoxy primer on it today. I will get some pics of this up soon.
Old 06-06-2006, 10:07 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
Well the poor old frame was needing some attention. I used about 6 cans of over cleaner and several hours with the pressure washer to get it this clean. Sandblasting will clean it up nicely though.
Old 06-06-2006, 10:41 PM   #7
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Lookin' sweet. What is wrong with the fit of the wheels??
FuelCellGuy is offline   Reply With Quote
Old 06-06-2006, 10:56 PM   #8
bagged74
its just $$$$$
bagged74's Avatar
too much backspacing on the rear. they are too far up under the fender for me. It fits perfect on the front though.
Old 06-06-2006, 11:04 PM   #9
FuelCellGuy
FUEL CELL GURU
http://www.ezaccessory.com/Wheel_Ada.../5500-5500.htm
I used these on the back of my Blazer. I had the same problem. I used the 1.5" version. VERY well made. Would be cheaper than a new set of wheels and just as safe. Later, mark
Old 06-06-2006, 11:38 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Progress is good. Keep it up buddy...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-07-2006, 06:58 AM   #11
n2billet
Village Idiot....
n2billet's Avatar
Glad to see you step off the deep end Once you get the tub back on the chassis, the hard part (mental) is over.
n2billet is offline   Reply With Quote
Old 06-07-2006, 08:58 AM   #12
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I'm running those on my 67 swb also. Got from same guy. Very good quality and fitment. I haven't had a single problem in 2,000 miles that they've been on. I got the 1-1/2" spacers on 20x8.5" wheels w/ 5.25" BS.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 07-02-2006, 09:54 PM   #13
bagged74
its just $$$$$
bagged74's Avatar
I really wanted to get the stance right on this one. Its pretty easy to get the front down low, but the back is always a pain. I knew a bolt in notch or a regular "c notch" wasnt going to cut it. I bought an 8pc step notch kit and proceded to bend and cut it to fit the contours of the rear frame. I know some of you "original" guys are probably gonna throw rocks at me......but I did cut a big hunk out of a factory 2wd frame.
Once I got the notch in I ran into another problem.......trailing arms hitting the frame. Luckily I had 10ft of 2x3 1/4" wall tubing, so I made some new trailing arms. This still did not completely fix the situation in the rear. I didnt want to mount the bags over or in front of the axle because I have dreams of having some sort of exhaust system in that area. so I decided to notch the trailing arms for the bag mounts. this gave me the clearance I needed and let me mount the bag approximately in the stock spring location.
Old 07-02-2006, 10:05 PM   #14
bagged74
its just $$$$$
bagged74's Avatar
This leaves me with the frame sitting level at 2.5" off the ground. I really want it a tad lower in the front so.........now I have to decide if I want to section the crossmember, or Z the frame, or leave it alone.
Old 07-02-2006, 11:29 PM   #15
BigMike
BigMike's Avatar
Wow, that is gonna be one sick little Blazer once it's done. I've had 3 Blazers but all 4X4's, always a soft spot in my heart for those 2wd Blazers. Keep on posting pics, no matter how insignificant you may think they are
Wish I had the funds and the lower back (blown L5/S1) to do my 69 that way...Little bit at a time I guess.
Mike
BigMike is offline   Reply With Quote
Old 07-06-2006, 04:32 PM   #16
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Sweet Progress!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-10-2006, 10:32 PM   #17
FnLow69
FnLow69's Avatar
any new progress...looks tits man keep up the awsome work...
FnLow69 is offline   Reply With Quote
Old 07-11-2006, 12:05 AM   #18
bagged74
its just $$$$$
bagged74's Avatar
I turned the frame upside down tonight and finished the welding. I also made some exhaust passages in the trailing arm crossmember. Tomorrow I will start painting some stuff. And I promise to take some new pics.
Old 07-11-2006, 12:10 AM   #19
72CSTC5
72CSTC5's Avatar
Any luck on the pics of your rotisserie for me?
72CSTC5 is offline   Reply With Quote
Old 07-11-2006, 12:13 AM   #20
bagged74
its just $$$$$
bagged74's Avatar
Dang man, Im sorry I completely forgot. I will take some tomorrow. I been running like
Old 07-11-2006, 12:13 AM   #21
72CSTC5
72CSTC5's Avatar
No problem, also how did you clean up the bottom side of the Blazer, sand blast or just sanded everything?
Old 07-11-2006, 12:15 AM   #22
bagged74
its just $$$$$
bagged74's Avatar
sand blasting is the only way to go. I did the whole bottom side in about 1.5 hrs.
Old 07-29-2006, 12:29 AM   #23
bagged74
its just $$$$$
bagged74's Avatar
Progress has been slow. Between work, trying to spend a little time with the family and the dang HOT weather I havent gotten much done lately. I have everything painted and the front suspension put back together. I found some carnage inside the rearend so now that is setting me back a little.
Here are a couple of pics my new front rotors and the trailing arms that I built.
Old 07-29-2006, 01:05 AM   #24
72CSTC5
72CSTC5's Avatar
Looks good, keep the pics coming. Thanks for the pics by the way!
Old 07-29-2006, 11:17 AM   #25
SCOTI
SCOTI's Avatar
What's the reason for the 'notch' where the rear-end would be positioned?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
