Old 07-25-2006, 03:11 PM   #1
74Chevy74
How did you measure/cut for you Z?
I just had a few last questions about Z'ing. Since the section where the frame is angled how did you guys make a straight line to cut the frame? I'm sure I could maybe use a level of the floor, and use a square but I don't know how close I will be? I just want it straight!
Here's a couple pics of what I got going.
74Chevy74 is offline   Reply With Quote
Old 07-25-2006, 03:23 PM   #2
74Chevy74
Re: How did you measure/cut for you Z?
Here's a few pics I found online of Z's....
Old 07-25-2006, 05:29 PM   #3
valleycustom
Level the frame out and use a bubble level to make your mark.
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 07-25-2006, 11:37 PM   #4
smbrouss70
smbrouss70's Avatar
Valley, when you say level the frame... you are talking about leveling the portion of the frame under the cab, correct?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-26-2006, 12:18 AM   #5
FnLow69
FnLow69's Avatar
i would assume so thats the flats spot of the frame but i would check the front frame horns as the same with the rear just to double check...
FnLow69 is offline   Reply With Quote
Old 07-26-2006, 11:08 AM   #6
valleycustom
Yup.
Old 07-27-2006, 06:03 PM   #7
Draggin79
Draggin79's Avatar
This is my 4" Z. (Sorry pics are so big.)
Draggin79 is offline   Reply With Quote
Old 07-27-2006, 11:44 PM   #8
jlaird
jlaird's Avatar
looks good. How long did that take ya?
jlaird is offline   Reply With Quote
Old 07-28-2006, 05:41 PM   #9
Draggin79
Draggin79's Avatar
it took a friend and I about a weekend to do it, most of the time was spent measuring before the cuts
Old 07-29-2006, 09:57 PM   #10
Rydn2L0w
Active Member
Rydn2L0w's Avatar
DO you guys "Z" the frame in order to avoid sectioning the crossmember? Or are you cutting off the rocker to lay door? From what ive read so far on this forum to lay pinchweld you need to section the engine crossmember to bring the front suspension up above the frame rails and replace the tranny and trailing arm crossmembers.
Rydn2L0w is offline   Reply With Quote
Old 07-29-2006, 10:15 PM   #11
7deuce
Sold! 2 days after finished
7deuce's Avatar
Thats what I did. Section X-member 1.125 in Z 2 3/4 in and ran 2x4 box tubing in the frame rails and blasted the bottoms off. Right now my X-member is 1 in off the ground and the lower A-arms are safe. Im going to get a 1 in plate and bolt it to the front X-member to DRAAAAAAAAAAAAAAG that pig down the road.
7deuce is offline   Reply With Quote
Old 07-30-2006, 09:34 AM   #12
Draggin79
Draggin79's Avatar
At first I did a 2.5" crossmember chop, I ended up having so many steering problems, that I decided not to use it at all. So I found a new crossmember, and decided to "Z" the frame. You "Z" the frame to raise the whole front suspension up and above the frame, therefor your not dragging off your lower control arms you will be dragging the frame section under the cab.
Old 07-30-2006, 01:23 PM   #13
XXL
Seņor Member
XXL's Avatar
Please stay in Ohio.
XXL is offline   Reply With Quote
Old 07-31-2006, 03:39 AM   #14
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 07-31-2006, 05:36 PM   #15
7deuce
7deuce's Avatar
Why should I stay here?????
Old 07-31-2006, 05:53 PM   #16
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Come on down to Orlando we are all getting together aug 5th sat for a drag thru to remember a couple fallen fellow mintruckers R.I.P - Matthew John Klausing - 3-8-77 / 8-2-05
Old 07-31-2006, 09:25 PM   #17
7deuce
7deuce's Avatar
Thanks.
Old 07-31-2006, 11:13 PM   #18
lownfast
Gettinlow & Goinfast
a bubble level and a sawsall will get the job done quick
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 08-01-2006, 05:14 AM   #19
camaro__thunder
XXL's truck wants to drag but he doesn't and wheres our update pics XXL ??
My Project 69 SWB
Old 08-01-2006, 12:26 PM   #20
74Chevy74
Here are some updates of what I did this weekend, still have not Z'ed the front. Here are the new notches installed and the KP 6 link, which is the nicest kit I have ever seen, and it was the first time something "Bolt on" actually bolted on! I highly recomend this kit.
Old 08-01-2006, 01:13 PM   #21
XXL
Seņor Member
XXL's Avatar
You must have done something wrong
Old 08-01-2006, 09:05 PM   #22
7deuce
7deuce's Avatar
Man, did you drill the holes out for the rear Xmember. That looks good. Keep the pics commin.
Old 08-02-2006, 11:36 AM   #23
74Chevy74
No I didn't drill the holes, the frame is actually an 85. Long story short, the truck was a long bed, we cut the frame to make it a short bed and I made the big mistake of not checking the squareness of the frame before we cut, we after we did the job we couldn't get it square. It turns out the truck was hit before, I ended up finding that out later! So I ended up getting a clean factory shortbed frame and the best part is I got it free!
Old 08-02-2006, 10:58 PM   #24
7deuce
7deuce's Avatar
Nice. Free is the best.
Old 08-14-2006, 01:08 AM   #25
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Thats why im only doing 1.5" section, and a couple universal joints. Dont you still end up with steering problems with the Z plus a whole bunch of other problems?
