choppin it up
Re: Got Bags???
is it laying to the cross member or are the wheel wells sitting on the tires
just wondering if it has the option of going lower with minor mods or if it would take alot to get it down further sorry about all the questions |
#2 | |
Outlandish Trends - FL
Re: Got Bags???
-Bret 67 short-fleet sold! |
#3 | |
choppin it up
Re: Got Bags???
Re: Got Bags???
Looks great dude ... you should be proud!
Straight jacket required
Re: Got Bags???
Are you using an adjustable panhard bar? And, does it hit your cross beam in the back on the right hand side? I just installed the rear axle, bags, the panhard bar, and 2 inch blocks, and mine hits. Any help and pics would be greatly appreciated. Also, what kind of shocks did you use and did you use rear relocator kit? sorry for all of the questions, just trying to get things right.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() Last edited by Inthuwind; 08-21-2006 at 02:34 PM. |
#6 | |
Re: Got Bags???
I am using CPP's bolt in c-notch, and ECE's super track bar. I ended up not needing to use the 2" blocks, as after I cut a small square in the bed to clear the diff, it still bottoms out the axle on the snubbers in the notch. The only thing that I needed to clearance was one of the bolts in the notch where it was hitting. I simply flipped the bolt and installed it from the bottom instead of from the top and it's fine now. If I removed the snubbers I would gain 3/4" in the notch and could use the 2" blocks, but I'd rather keep the snubbers in there and be able to slow-cruise aired out all the way. Metal on metal banging together doesn't sound or feel too good. I'm running Doetsch Tech shocks and the ECE relocator kit. What pics do you need me to take for you? If you can specify I'll try to do it for ya. I'm leaving for the RA show in Tennessee thursday night, but sadly not taking my truck now due to money issues but I'll be back Monday, so PM me if I don't answer here and I'll get back to you.
Re: Got Bags???
That looks great! What bags are you running? The kit I just bought came with 2 Slam Specialties rs-62's and 2 rs-72's. I can't wait until it gets here.
I also got the drop spindle disc kit for the front, c-notches, and the super track bar on it's way too. I should be starting my long awaited under-stuff in a week! The timming couldn't be better, my left front wheel bearing burned up on the freeway last weekend ![]() |
Re: Got Bags???
[QUOTE=jimmydean;1787473] What bags are you running? QUOTE]
I'm running Slam RE7's front & rear. They ride awesome. Reason I bought them was from all the good feedback I heard on them. It could be me, but they seem to be built better than the 'stones, and I like the internal bumpstop feature.
#9 | |
Re: Got Bags???
That looks damn nice. Makes me motivated to get mine done (even though I don't have everything just yet). My setup is very close only I got everything from CPP. <edit> Also, are you going to run two tanks and two compressors, or just two compressors? To buy a second compressor to match the one I have is $180, but I don't want to try and fit a second tank as well. Last edited by jimmydean; 08-29-2006 at 07:37 PM. Reason: Added question. |
#10 | |
Re: Got Bags???
I had a hookup on the 380's. Paid $130/ea. for 'em. ![]()
Re: Got Bags???
No pics necessary now, I got mine in good order. Thanks for the info. Your's is looking awesome!!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Re: Got Bags???
Ok, that makes sense with two 3-gallon tanks. I have one 7-gallon that "should" fit somewhere. I hope with that and the single Thomas I have it should be enough. I don't plan on doing a lot of fill/dump, but it would be nice to have enough to adjust when needed.
Re: Got Bags???
I said that too before I had bags.... But I'm still in the "infantile stage" of having bags so I'm a little switch-happy.
Re: Got Bags???
#15 | |
Re: Got Bags???
#16 |
Re: Got Bags???
Thanks! I'm running 255/35/20 all around. You may have some issues getting low with those tires up front. Also out back I'm not sure, but you might have clearance issues as well. Those are some big meats!!
