Old 08-07-2006, 10:20 AM   #1
Myself
Put some time in on wife's 68 this weekend.
New pic on last page!
We all put some hard time in on my wife's 68 swb this weekend. This truck was red Friday afternoon! While my wife and son were running sanders I was switching between bodywork and fabrication. Everything is ready now for the 20 gallon S-10 Blazer fuel tank to be put in. The best part is it doesn't hang as low as other tanks, and the gas gauge even reads right! I'll finish bodywork and have it in primer by Thursday. In time for the big cruise in Branson Mo.
Myself is offline   Reply With Quote
Old 08-07-2006, 11:00 AM   #2
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: Put some time in on wife's 68 this weekend.
Too cool
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 08-07-2006, 12:56 PM   #3
BOSS
Just here to help
BOSS's Avatar
progress is sweet! When is the big Branson cruise?
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 08-07-2006, 01:14 PM   #4
Very Nice. I'd like to see more about the S10 tank install, ie how she sits in and the fill nozzle...all the neat stuff.
Old 08-07-2006, 01:25 PM   #5
matthufham
i just fell in love with that truck. it has the same wheels as mine so it reminds me of my truck a few months ago. i want to do some bodywork.
matthufham is offline   Reply With Quote
Old 08-07-2006, 01:57 PM   #6
Myself
The Shephard of the Hills car show and Super Summer Cruise is this weekend!
Old 08-07-2006, 03:37 PM   #7
49studebaker
49studebaker's Avatar
Ya, I'm with Palf, lets see some pictures of the S-10 tank. I've got a donor Blazer but didn't know what I'd run into using the tank.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 08-07-2006, 04:08 PM   #8
see ten
WTB this ad
see ten's Avatar
+1 on the S-10 Blazer tank install. I would also like to get the tanks out of the cabs of my trucks. I just always thought that the full size blazer tanks hung down a little low for my taste. ECE makes a sweet fuel cell that's up high but the price is on up there!
see ten is offline   Reply With Quote
Old 08-07-2006, 04:48 PM   #9
jadkins08
The truck is great, but the best part has to be finding a wife who understands the value of an old Chevy truck. My wife won't even ride in mine of course I haven't done much work on it yet. I bought her a new pair of BIG diamond earrings so she won't go crazy when we get the credit card bills for the parts I have bought. I love my wife and she is great but if she told me she wanted a 68 Chevy to restore I would probably fall over with a heart attack.
Jeremy
jadkins08 is offline   Reply With Quote
Old 08-07-2006, 05:36 PM   #10
Myself
Well, it's only fair. I have an S-10 Blazer that I put a smallblock in and spent a lot of time and money on it. Then, summer before last I bought a Trans Am off E-bay and went to San Diego to get it. Then when we got back I did a little body work on it and painted it. (She did get a vacation out of that, does that count?) She decided she wanted one of these old trucks so, here we are. Fair is fair. And I've already redone the motor, trans, and brakes too.
Old 08-07-2006, 07:03 PM   #11
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Hey, Myself, where in North AR are you located ?
I'm in Mtn Home.
68shortstep is offline   Reply With Quote
Old 08-08-2006, 01:29 AM   #12
nevada70chev
You should do a tech write-up on the install of the S-10 tank, I'll bet there are plenty of them in the j-yards. Thanks.....
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 08-08-2006, 04:49 PM   #13
see ten
WTB this ad
see ten's Avatar
It looks like you made a pretty good size cut on either frame rail and welded in a brace at the rear of the frame. Do you have any pics with the tank installed?
Old 08-08-2006, 05:36 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Progress is Progress, no matter how much or how little, Nice work
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-14-2006, 06:16 PM   #15
Myself
Okay, I was working on the truck all last week and got it in epoxy primer. Spent many hours with a long board. The fuel tank is in and looks good from behind, although if I did it again I would do a couple things different. First off the S-10 Blazer tank needs mounted with the fuel filler neck towards the driver side. With it on the passenger side it sits just in front of the rear bed crossmember. That's more cutting and a longer tube to bend for your filler. Also don't mount your filler cap onto the bed floor. The fuel won't drain fast enough and it takes a million years to fill up! I'll have to reposition it higher. Other than that it works great. I left the factory fuel pump in the tank with no problems. The mechanical pump will suck fuel right through it. The rear bed crossmember will have to be notched out, and in my case notched a little higher in the area right above the sending unit. The upper front part of the tank straps will bolt right to the frame after you drill holes. The lower front of the straps need about 1 1/2" spacers bolted to them to drop them down a bit. I cut a couple from square tubing. The rear frame crossmember needs removed and a new one put in place farther back. I used 1 1/4" thickwall angle and welded it inside the frame towards the bottom. That way you can still bolt your bumper back on. The top and bottom tank straps will bolt to your new rear crossmember together after you drill the rivets out of the upper straps and unfold the doubled up part. Then just enlarge the last hole. Don't forget to drill a small hole for your ground wire! Also, some 3/8" rubber fuel line slit lengthwise works good as an isolator to keep any parts of the tank from rubbing on the frame if you mount it that close. Here's some pics.
Old 08-15-2006, 10:02 AM   #16
Myself
Some more pics.
Old 08-15-2006, 10:24 AM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
Man, that looks great!
You said the truck was in primer??? So you cleared the primer, or is the last pic paint? Looks good either way.
Post some pics with the back bumper on so we can see how low the S-10 blazer tank sits when you git r done
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-15-2006, 11:14 AM   #18
Myself
In the last pic it had just got done raining. It's black epoxy primer.
Old 08-15-2006, 11:49 AM   #19
krue
Designated A-hole!
krue's Avatar
I like the blazer tank! Definitely need a FAQ write up on that one.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-16-2006, 12:07 AM   #20
sdkid
Yeah, what he said. Does it matter what engine the s-10 came with?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 08-16-2006, 12:36 AM   #21
ERASER5
ERASER5's Avatar
So if I put in an S10 Blazer tank with the fuel pump in place, I can just run the mechanical pump and pull through the e-fuel pump. And later if I go with an EFI, the e-fuel pump is already in place. One of those two-birds-one-stone deals.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-16-2006, 09:28 AM   #22
Myself
Yes, fuel pump in place, everything as factory, the mechanical pump will suck fuel right through it no problem. I'm pretty sure all 83-94 S-10 Blazers, S-15 Jimmys, and Olds Bravada have the same 20 gallon tank. Only 86-up will have the fuel pump in tank.
Old 08-16-2006, 11:25 AM   #23
WyoRoadDog
Page intentionally left blank.
WyoRoadDog's Avatar
Nice work, good job on the tank as well! I'm going to keep this in mind for my tank swap plans. Thanks for the info!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams
'67 GMC 4x4, 305 V6! Or all the parts for anyway...
'17 Subaru Outback.
'18 Toyota Tacoma TRD Off Road.
'99 Ducati 900SS.
WyoRoadDog is offline   Reply With Quote
Old 08-16-2006, 11:29 AM   #24
5150
C10 Club Tennessee
5150's Avatar
Ditto, we need a FAQ written on this. S10 Gas Tanks are SUPER CHEAP at the pull-a-part in Nashville. They are also plentiful.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-16-2006, 04:09 PM   #25
see ten
WTB this ad
see ten's Avatar
I would also like to see how low it hangs below the bumper. Keep us updated!
