Old 08-12-2006, 06:51 PM   #1
shelby987
shelby987's Avatar
Best MPG for a 2wd 67-72
I am going to try and start two threads here, not really a poll, more of looking to set the bar for MPG (which seems to be a big topic of discussion these days).
I wanted to know what is the best MPG you have gotten with your 2wd, and what your setup was....Tires, Ride height, rear gears, transmission (manual/auto...OD?), engine (details such as ele. fan, carb/efi/tbi, exhaust, hei, etc). I know there are people on here with small V8's, I6's, V6's, Diesels, just trying to see what combinations produce the best results.
I don't want to turn this into what doesn't work, we all know how to get below 15mpg.....we all know how to get 4mpg!.....lets try to stay on topic as best we can.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 08-12-2006, 07:11 PM   #2
SB406
FORD is a 4 letter word.
SB406's Avatar
Re: Best MPG for a 2wd 67-72
'71 short box
small block 406, TBI, Vortec Heads,RV Cam, custom (home-made) chip, clutch fan, Stock Exhaust Manifolds, Dual Exhaust, 700R4 auto trans (OD), 3.42 rear gears, 255/70 R15 (~28" tall) Rear tires. Standard Ride Height. No Bed cover, MSD 6a & blaster coil.....
87 Octane
16 MPG City / 21 MPG Hwy
'71 406 GMC Short Box Fleetside - Daily Driver
'79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com
'58 LT1 Chevy Short Box Step Side - Next Project
SB406 is offline   Reply With Quote
Old 08-12-2006, 07:22 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
350 w/ points, 7mm wires, R45TS plugs, stock air breather setup, thermo clutch fan,1976 Q-jet, original cast iron intake, 1.94cc camel hump heads. Grandpaw rebuilt the engine in 1978 or 1979. Has a TH400 out of a 1967 Caprice, I've never done anything to it other than change the fluid and vac. modulator, it'll get a new torque converter soon. Rear is the Eaton/Corp. 10 bolt full floater with 4.10 gears running 33-12.50-16.5 BFGoodrich A/T's. Has a 2 1/4" dual exhaust with 18" glasspacks dumping underneath the front of the bed. It got about 11-12MPG on the highway before the dual exhaust and new tires, should get a little more now.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-12-2006, 09:13 PM   #4
WizzKidd!!
71 LWB, newer (90's?) 350 (i know it has 86 and later cast iron heads), TH350, Edelbrock 600cfm, performer intake, headers, dual 2 1/4 exhaust w/ flowmasters, 31' wildcats (pretty much bald), and unknown gears. I go about 55 @ 2000rpm in drive if that helps...
Adjusted for speedo being off I get about 14-15 mixed driving.
WizzKidd!! is offline   Reply With Quote
Old 08-13-2006, 06:44 AM   #5
junkyardjohn
junkyardjohn's Avatar
11.... 12 If I'm Lucky John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-13-2006, 09:36 AM   #6
see ten
WTB this ad
see ten's Avatar
14.75mpg out of my C10. 350 engine, Th350 trans, 3.08 gears. Engine driven fan removed and replaced with electric. HEI with MSD coil and wires, edelbrock intake, roller tip rockers and March Performance underdrive pulleys.
see ten is offline   Reply With Quote
Old 08-13-2006, 11:41 AM   #7
355
355's Avatar
16+ at 80 mph, 3.07 gears,255/70 tires/ 700 r4 w/od and lockup, 355. you can read the rest in my signature.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 08-13-2006, 11:47 AM   #8
Shane
Shane's Avatar
I haven't put any gas in my '67 in over 5 years ...
Shane is offline   Reply With Quote
Old 08-13-2006, 12:02 PM   #9
Roachgod
Roachgod's Avatar
Whoops my fuel slowly leaked out last weekend after we pulled the vortech 350 out of her so for now 0 mpg without even a motor. I'll post hopefully next weekend if I get the time to drop my new 454 in there.
1970 custom/10 (was 8-350)
long bed
factory a/c,power steering, power brakes
added front disc brakes from a 72 and rear axles 5 lug
79 chev 1 ton
01 GMC Jimmy
Roachgod is offline   Reply With Quote
Old 08-13-2006, 03:07 PM   #10
jku72
I'm getting 18 highway with my suburban. The thing is that most people make modifications that increase power without thought to what it does to efficiency or mileage. It sort of makes sense, cause if you want great fuel mileage, you'd buy a small car.
But, for stubborn people like me that want to drive the old trucks, yet still not get terrible fuel mileage, there are things you can do. The big items that improve mileage are gears, headers, and higher compression ratio.
The big killers of mileage are usually high performance cams, deep gears, and big bore carburators.
Even if you put an overdrive in a truck, the big cam and carburator still kill you.
The reason 292 6 cylinder trucks don't get good mileage is the low compression ratio, great for longevity, but hard on gas. Even the 250 6's are much lower compression that the v-8's. (of the time). One of the things that I notice is that the new crate 350's are low compression engines, e.g. they will never be efficient. Lower emissions, but suck the gas.
The reason diesels are so great is the big compression.
My thinking on a good mileage setup, that still made decent power:
283 with around 10-10.5 compression, aluminum heads, stock cam, HEI, small tube headers, quadrajet carb(primaries are smaller than even a 2 barrel), 3.42 rear end, and an over drive trans. If no overdrive, then I'd run either a 3.07, or if you had a sm465 4 speed, I'd run a 2.76 rear gear.
My current burb has 10:1 compression 350, iron heads(not stock, they are from a 1969 or 70 camaro) stock cam, q-jet, HEI, sm465 trans, and a 3.07 rear gear. Thats with a crappy single exhaust coming off iron manifolds. It makes good power down low, and cruises nicely, although the overly restrictive exhaust drops the mileage quickly over 70 mph.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 08-13-2006, 03:54 PM   #11
Josh
He's got mean nasty FANGS!
Josh's Avatar
Best I've netted on my 69 was 18 highway @ 70mph. I achieved it with a qjet, the stock cam/bottom end, set of 487 large valve heads, old camaro SS factory performance intake, good HEI, a fresh tune up, 235/75/15 tires and 3.07 gears. Engine has around 9.5:1 CR and pulls good down low just lacks a lil top end The best I can manage in the city if I keep my foot out of it is 14mpg. Otherwise I get around 12mpg..
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 08-13-2006, 04:43 PM   #12
71chevytruckguy
71chevytruckguy's Avatar
'69 swb, '86 305 with q-jet carb, offenhsauser dual port intake, comp 268h cam, flat top pistons, hei, accel 300+ plug wires, accel shorty header plugs, flowtech headers, running on 93 octane, 2 1/4" dual echaust with flowmaster 40's. trans is a 4 spd saginaw, 3.43 rear gears, 275/60/15 tires, lowered about 2"/4". best mpg is 12 city and 20 highway. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 08-13-2006, 07:03 PM   #13
396C20
396C20's Avatar
I just checked this morning. I got 13 mpg combined city and hwy.
69 LWB, fresh stock type rebuild of the 396 with the exception of Comp 254 advertised 4x4 cam, MSD Hei, Holley quadrajet replacement carb with the black spring in the vacuum secondaries (it opens the secondaries at a higher rpm), stock manifolds with full length 2 ½ in dual exhaust with an x pipe. Stock suspension and ride height 245/75/16 tires.
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen
67 Chevy C20 CST
396C20 is offline   Reply With Quote
Old 08-13-2006, 09:54 PM   #14
TP from Cntl PA
TP from Cntl PA's Avatar
Got 15 or so with the 350 in my '71 C-20.............Put the Cummins in it, and it doubled and then some! No highway use, just two lane black top and gravel roads/lanes.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 08-14-2006, 07:40 PM   #15
Buckman
2wd 71 with a 355 w/700r4 od. Mix I get about 14-15, Hwy I get about 16.5.
Buckman is offline   Reply With Quote
Old 08-14-2006, 08:44 PM   #16
pumper578
pumper578's Avatar
not really bragging but i get about 13-14.5 MPG, but my speedo doesnt work so i am just guessing ( 56 miles to and from work and 4 days = 224miles/17.5 gallons= 12.8 MPG)
pumper578 is offline   Reply With Quote
Old 08-14-2006, 10:11 PM   #17
carl609
carl609's Avatar
67 long bed, lowered, but not enough, 275/60s in the back and 245s in the front. 350, 286h comp cam, roller rockers, big valve heads, holley two barrel, th 400, 3.73s. I built the engine for a street stock race car, so mileage wasn't a concern. Even with the 2 bbl, I am lucky to get 10mpg, more like 6-8. I have a fairly heavy foot though.
carl609 is offline   Reply With Quote
Old 08-14-2006, 11:14 PM   #18
Goose
Goose
Goose's Avatar
'72 GMC step 350/350; 3.08 gears, 600cfm Edelbrock;mild build on engine runs on 87Octane, headers; lowered slightly, Checkmate bed cover; and 235/60/R-16's rear. Ave. 11.5. I saw 14 once with a good strong tailwind.
'72 GMC short-step 350/350
Goose is offline   Reply With Quote
Old 08-15-2006, 08:05 AM   #19
Huck
Huck's Avatar
My 72 cheyenne with crate 350, stock intake, HEI, 5speed, 307 posi, would get 18-20mpg hwy. Things that hurt it--edelbrock intake and headers!! Things that really helped it==edelbrock carb, 5speed, bed cover.
My 2000 Silverado 4x4 extended cab gets 20-21 hwy with 373 gears and bed cover. The bed covers show 1-2mpg improvement!!
My wife's 06 Honda civic==40mpg!!!
My daily driver Cavalier convert ==25 in town and 30hwy.
Huck is offline   Reply With Quote
Old 08-20-2006, 04:25 PM   #20
Greubin
Greubin's Avatar
Here's mine, I'm still tuning..
'71 C20 w/ crate 350 290HP, HEI, Edelbrock 1406, BTO 700R4, 4.10's and dual exhaust. With about 1000mi on the eng/trans I'm getting 12mpg mostly commuting. I've heard the 1406's run rich so I need to check into running smaller jets / tuning carb. Plugs are tan though.
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 11-20-2006, 10:58 PM   #21
Greubin
Greubin's Avatar
I'm up to 15mpg, rejetted carb, adjusted float height to spec and connected vac advance pod to "ported vacuum".
___________
Greubin
Old 11-20-2006, 11:47 PM   #22
Green Machine
Green Machine's Avatar
18.2 MPG some town, mostly highway untuned from 1970 C10 LWB, 89 Camaro 305 (was TBI) with stock roller cam and swirl port heads. Performer 2104 and Edelbrock 1406 stock jetted(so far). Ram horn manifolds and crappy duals. 3.73 posi with 265/70-17 tires and 4 speed manual with .73 over drive. 60 mph=1700 rpm.
Will add headers, better exhaust, tune the carb and tweak the dizzy this spring. Hoping to beat 20 mpg.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-21-2006, 01:22 AM   #23
BCOWANWHEELS
well i got a 1971 c10 with 286000miles on it.it has a stock 250 6cyl, 3 on the tree, 235r15 tires and at 60 mph it gets 14.5 mpg loaded or empty. 65mph it goes down to 13.8.
BCOWANWHEELS is offline   Reply With Quote
Old 11-21-2006, 04:15 AM   #24
Goose
Goose
Goose's Avatar
I have the 1605 as well - what size jets did you end using? What RPM are you turning to get 15mpg? Did the leaner jets affect your acceleration performance? Thanks.
Old 11-22-2006, 12:22 AM   #25
bazkook
Not to get off subject here but I plan on putting a Ram Jet 350 crate motor in a 70 C10 I'm about to fix up. What kind of gas mileage could be expected with a 700R4 and either 3.73 or 3.42 gears?
bazkook is offline   Reply With Quote
