Old 09-19-2006, 01:42 PM   #26
pharcyde05
pharcyde05's Avatar
Re: Air Ride List. What else do I need?
hear is a full link set up with bags behing axel its trianglated so there in no pan hard bar
pharcyde05 is offline   Reply With Quote
Old 09-21-2006, 12:15 AM   #27
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Point well taken about the line sizes and speed. I am going to stay with the leaf spring rear-end so my choices on bags are somewhat limited. The Air-Over-Leaf systems with tapered bags are about my only choice. Most of the bags I have seen with these systems have a 1/4" inlet. Based on what you suggested, I may go with larger valves and lines and reduce just before I get to the bag.
As far as the deflated rear height goes, when the vehicle is sitting on the springs, it is as low as it will go (without hitting a bump of course). I am thinking about 8 or 9 inches of total drop in the rear. I already have about 7" with the flip and re-arched springs and will probably add some blocks to get it down the extra couple of inches.
Thanks a lot for your input. I will check out the Slam bags a little more and see what else they have for my application.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 09-21-2006, 11:46 AM   #28
pharcyde05
pharcyde05's Avatar
you dont have to stay with the sleave bags you can put some of the standard bags on with a over the axel kit where you mount a pearch on top of axel for bottom of bag to attach then put crossmemeber in at the top of the notch where the top of the bag can mount i am still trying to get you some pics i will shearch more today
Old 09-21-2006, 08:25 PM   #29
pharcyde05
pharcyde05's Avatar
