stupid brake question
The brake system is setup so that if a front or rear brake line breaks and leaks out only the front or rear will be no functional leaving the other half unafected. So you would still have one or the other correct. So you would have to lose pressure in both to have no brakes. Is this correct?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: stupid brake question
Yes.
My Blazer had a rear wheel cylinder that leaked all the fluid out of the rear of the system and a seized driver's front wheel cylinder. Only the front right brake worked!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
LOL i bet it pull's like crazy to the right when you brake?
its all about the +6 inches
While that is technicly true, don't count on it to stop you very well. If the rear goes out, you may be OK, but if it is the front that goes out, think of that pedal as a delayer... not a brake.
No longhorn man I would not count on it. Was more of an observation and wanted to ask to satisfy my curiosity.
![]() Join Date: Sep 2005
my rear brakes went out going down the road my truck would not stop untill i put a plug in the rear port of the mc but yes thats techinaly true
laying low
![]() Join Date: Mar 2001
Well ol Leroy whateverhislastnameis deserves a hardy pat on the back for this idea. Two more or less independent brake systems in case a wheel cylinder fails or a brake line breaks. If one end fails you should still have "some" brakes left. Since the front brakes do about 80% of the work I would rather the rear ones be the ones to fail if it has to happen.
Then, if one can remember it in an emergency, one can step on the parking brake. Is yours adjusted correctly? ![]()
It did, was scary as all getout. Made me go straight for power discs instead of fixing any of the manual drum hardware. Very first thing I did to the thing after I got it running.
