dang its hot
Re: Help With Motor Issue...
cool man, not pointing fingers or criticising, I've seen alot of guys go off and chase their tales, just trying to help and if I offended you, I apologize and Merry Christmas to you!
dang its hot
tails
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Hey Grinch,
I'm sorry for sounding short. We can help this guy out together. I should be the one called GRINCH today. I'm just in a mood as this is the first Christmas in 7 years my family and I are spending away from my mom who misses her Grandchildren more than anything. Happy Holidays Buddy.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
dang its hot
Austria? Good Lord! I understand, I have been away from my home in Maine since 1978. This is the first Christmas I will not be with my grandchildren in Illinois but God is good and he is with me and you! I pray for them all the time. And I'll say one for you and your Mom. Peace bro
KEEP ON TRUCKIN'
Thank's, and I'll do the same for you.
took all plugs out and put the compression tester in 6 and it sounded like i could hear air coming form somewhere like woosh woosh woosh as motor turned over.... only that cylinder really does it 4 may too i dont know...
1973 Chevrolet C20 (Under Construction) |
dang its hot
refer to post #44, determine where air is escaping.
Chevy truck addict
Like said many times, im sure you have a blown head gasket. sounds like you have a blown head gasket between 4 and 6. id just pull the head and check it out.
im in norman...you got any parts or trucks for sale????
Broken Down
Just like (grinch4om) said do a cylinder leakage test... bring your number 4 or 6 up to TDC on the compression stroke remove both #4 and #6 spark plugs add 90-100 PSI through your spark plug hole on cylinder you chose and listen if air escapes through the carburator its a bad intake valve, thourgh the exhuast bad exhuast valve, though the oil fill or pvc bad rings, or if air escapes from sister cylinder you deffently know its the small portion of head gasket between the two that has gone bad. Good luck and I hope you don't spend a arm and leg on repairs.. Merry XMAS
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
![]() Join Date: Apr 2005
I've often heard that when you install rebuilt heads on a blocks that has alot of miles it often leads to increased oil use, blow by, etc. My opinion just replace the head gasket until you can get a overhaul done.
well i started it... went out and did what i could, i almost got the intake off 4 more bolts left then i will pull head and see whats hidden underneath
INTERESTING... i was able to read the castings on the block easily... 3970014... it says 70-76 350 with a 2 or 4 bolt main, i asked the guy i got it from and he said its from another truck and it is a 4 bolt main... is that good?
Chevy truck addict
4 Bolt mains are very good. good block to built a high horse motor out of. Very strong block.
#15 |
AwEsOmE!!! It say's 70-76 my truck is a 78 and it has H.E.I.... When did this come out? I want to know the year but its not that bigga deal... If i order 78 chevy c10 parts for a 350 would they still fit even though mine is a 70-76 motor??? by the vin it says came with a 305... also its a bonanza what is that???
#16 |
intake is off, i am starting to think that when its time to REASSEMBLE its going to be a hassle and hard to do... is it???
#17 |
7000 #'s of american IRON
if you clean the mating surfaces, it shouldn't be too hard
IF you have a boat anchor intake, disregard that statement and get a hoist/a-frame/crane.... |
