Old 02-06-2007, 05:51 PM   #1
jorgensensc
jorgensensc's Avatar
Show me your Mig Welds!!!
I finally got gas for the Lincoln Promig 135. I started playing around with it and the welds look 100% better. At first they didn't improve much, but then I realized I was using the wrong tip diffuser thing. I changed that out and now the welds look like smooth snakes, not really a roll of coins though.I did a butt weld on a couple of scrap pieces and I think it looks good, but I would like to see your welds to make sure mine looks close. So can y'all show me some good Mig welds with gas before grinding smooth? I appreciate it!!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-06-2007, 06:51 PM   #2
CJJ67
Re: Show me your Mig Welds!!!
What tip diffuser thing? I can't weld worth crap no matter what I do, but I keep trying. If I knew what it was maybe I could change mine too. Probably wouldn't help my skills.
CJJ67 is offline   Reply With Quote
Old 02-06-2007, 07:01 PM   #3
lytemup454
lytemup454's Avatar
lytemup454 is offline   Reply With Quote
Old 02-06-2007, 07:12 PM   #4
BarryB
BarryB's Avatar
take a roll of dimes and fold them over and that is what my welds look like.
BarryB is offline   Reply With Quote
Old 02-06-2007, 07:36 PM   #5
watahyahknow
watahyahknow's Avatar
with mig it doesnt look like a roll of coins most of the time unles you weld with short bursts its like half a sec on the spot move a little and zap again half a second
a continuous weld looks just like that a continuous weld if its the same bead and it has penetration all the way through the metal youre doing a good job
the famous coins are more a tig weld thing where you can add filler rod and vary youre output
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-06-2007, 08:05 PM   #6
rage'nrat638
rage'nrat638's Avatar
heres some goofy head stands i just made not a lot of welding
rage'nrat638 is offline   Reply With Quote
Old 02-06-2007, 09:09 PM   #7
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Here are a couple shots of the welds on my crossmember section. I didn't spend a lot of time cause no one is gonna see it anyhow. And, a pic of digger just for good measure. Bet there's some good welds on that sucker!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 02-06-2007, 09:23 PM   #8
msgross
msgross's Avatar
mine looks like bird poop! after eating berries!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-06-2007, 09:26 PM   #9
rage'nrat638
Old 02-06-2007, 09:27 PM   #10
GREASEMONKEY72
GREASEMONKEY72's Avatar
the roll of coin weld isnt just for tig, but with the gas mig or flexcore mig my welds look like a roll of coins how much like it does vary and it also varies on the aplication its doesnt always HAVE to be a roll of coins as long as you have good penetration its good i personaly think the roll of coins looks cool so i do it alot but its not needed
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 02-06-2007, 09:28 PM   #11
hchad18
hchad18's Avatar
I could never get a real good weld with my 135. Bought the new 175 and love it.
hchad18 is offline   Reply With Quote
Old 02-06-2007, 09:28 PM   #12
GREASEMONKEY72
-steven
Alte Seele S.S.
Old 02-06-2007, 09:29 PM   #13
shortbed70
shortbed70's Avatar
I'll have some soon when I get my gas
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-06-2007, 10:30 PM   #14
jorgensensc
Here is the only few I got done before I left to pick up my little one from school:
The one on the left is one with gas, but the wrong diffuser thing. I changed it and got the weld on the right.
THis is an up close of the weld on the right:
Here is the backside of the one on the right side (the one I think is okay). THe weld doesn't look like it goes all the way through, but it almst does..
I know I need more practice, but am I on the right track with the one on the right? How do I get the weld to go a little deeper on that one? I am at the max voltage. Do I just slow the feed and stay on spot a little longer?
Thanks for the advice.
Also, what should my gas pressure be at? I've got it set at 15 psi right now, is that right?
Shawn
Old 02-06-2007, 10:47 PM   #15
ChevyCrazy67
ChevyCrazy67's Avatar
Or it looks like where a coon took a sh#t on a log and walked through it backwards. Thats what my shop teacher used to tell me.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 02-07-2007, 01:45 AM   #16
lytemup454
lytemup454's Avatar
jorgensensc slow down! your crown is too high and you have arrows instead of snake belly's. your on the right track. you might want to play with your wire speed a little.
Old 02-07-2007, 03:28 AM   #17
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
You will search far and wide to find welds any better than PORTERBUILT lays down. Search some of his threads and you can set you goals high and strive for his level of performance. That is coming from a circle track guy that has seen alot of welds. I only wish to have welds as nice as his someday. I'm sure alot of guys on here will agree. Looks like your on the right track though practice makes better because no one is perfect.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 02-07-2007, 03:59 AM   #18
watahyahknow
yup porterbild and trepanier from rad rides have allmost the same welds its allmost spooky
Old 02-07-2007, 07:23 AM   #19
70LongbedC20
70LongbedC20's Avatar
No beads on this picture. But good penetration. This is my homemade Chevelle flatbottomed floor. Welder made a big difference. Started with an Italian MIG that was really inconsistent with the temperature. Got a cheap German welder and saw a big improvement.
70LongbedC20 is offline   Reply With Quote
Old 02-07-2007, 08:09 AM   #20
jlaird
jlaird's Avatar
The pics your seeing of portorbuilts welds are awesome, but not MIG. Your not going to get MIG beads looking that nice.
jlaird is offline   Reply With Quote
Old 02-07-2007, 11:14 AM   #21
jimmydean
jimmydean's Avatar
I thought Nathan's work was all (or mostly) Tig. You are right about his welds, though. A thing of beauty to behold.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-07-2007, 11:26 AM   #22
bcanini
"Taste It"
bcanini's Avatar
Shawn
Gas pressure should be at about 5-7 lbs too much gas pressure will pull oxygen into the puddle and cause porosity.
Looks to me that you are a little hot and not enough wire feed??? too much spatter. this can also be controlled by arc length (wire stickout from the contact tip) too much you'll get spatter. I've always set my welders by the sound. I'll set my heat to the material thickness then match my wire speed for the sound I'm looking for. It helps to have been welding for a living for 18 yrs.
If you're doing spray transfer it should hiss, if you're doing short arc it should buzz
The way I usually start setting my welder is say my welding heat setting is 5
I'll set my wire feed at 60
Also if you really want nice clean welds take a second w/ agrinder and clean the surface you're going to weld (take the scale off) just make it shiny no gouging just a quick swipe.
If you've any more questions feel free to post I'd be happy to help,that goes for anyone (I'm not an expert but I did sleep at a Holiday Inn Express) I've become a desk jockey and truly miss being in the shop. I've built everything from food processing equip, to cell towers,buildings and lots of custom aggregate processing equip (huge stuff) and lots of stuff in between.
Hope this helped
Brian
71 Chevrolet short fleet Cheyenne air cab/tilt w buddy buckets pretty stock other wise.
2007 Silverado Crew with the MAX Pack and loaded
2007 CX-9
"Hopefully when I die.. my wife wont sell my stuff for what I said I paid for it"
It's easier to ask forgiveness than it is to ask permission.
bcanini is offline   Reply With Quote
Old 02-07-2007, 01:46 PM   #23
watahyahknow
the sound youre looking for when welding mig is the sound of eggs and bacon frying in a pan not realy spattering but more sizling
Old 02-07-2007, 02:21 PM   #24
1lowdiesel
1lowdiesel's Avatar
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 02-07-2007, 02:34 PM   #25
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
This is the pic I have handy of a recent weld. It was done with a miller 175.It is the plate on the side of my frame where I Zd it.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
