Old 03-18-2007, 01:38 PM   #1
BaddBusa2005
BaddBusa2005's Avatar
Flip Kit Questions
I would like to know when you do a flip kit and noth the frame, do you have to cut the bed floor at all?
I would also like to see some pics of the flip kit installation if anyone has them.
Thanks,
Ryan
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 03-18-2007, 02:07 PM   #2
los-lowrider
los-lowrider's Avatar
Re: Flip Kit Questions
I have a Western flip kit installed and all I have to say is that I had to work on my bed in combination with an 2" habger. Pics are availible at www.los-lowrider.com then on tech-corner
Best Regards from Germany!
los-lowrider is offline   Reply With Quote
Old 03-18-2007, 02:26 PM   #3
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
best i have for now, 4 1/2 and 6" drop, the answer is no.
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 03-18-2007, 04:46 PM   #4
pcmcobra
pcmcobra's Avatar
i put a flip kit on my 86, no notch, rides fine. I don't haul anything in the bed either, and drive like a granny.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 03-18-2007, 05:09 PM   #5
BaddBusa2005
i dont haul with my truck either, but i do let people know it has a posi from time to time
Old 03-19-2007, 03:08 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
for a flip kit you don't have to do anything to the bed.
If you put shackles on you would though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-19-2007, 03:14 PM   #7
boatpuller
boatpuller's Avatar
mine's flipped and c notched with no bed mod's.ride's ok.i don't haul or pull nothing with it.i suppose it's load limit isn't much.but if your looking to drop it.i doubt your going to use it as a work truck anyway.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-19-2007, 04:51 PM   #8
BaddBusa2005
exxxxactly
Old 03-19-2007, 05:03 PM   #9
hiway
Mad Scientist
My bro's 81 is flipped. Factory spring pack, shackle, and hanger. No notch and no issues. Ran 9.50's in the thousand ft. without issue.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 03-19-2007, 06:10 PM   #10
swervin ervin
You get what you pay for
swervin ervin's Avatar
If you use Western Chassis C-section, you will have to notch a tad on the bed. It has bolts on the top and they will hit. At least they did on mine.
http://www.73-87.com/7387garage/chas...n/csection.htm
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-19-2007, 06:47 PM   #11
bigblock73
yeller
bigblock73's Avatar
If you put hangers on you would though.
Hangers no, shackles yes.
bigblock73 is offline   Reply With Quote
Old 03-19-2007, 07:19 PM   #12
Survivin Project
Survivin Project's Avatar
Ya like bigblock73 said... but it dosent hurt well you are there to do it, just for future... I did mine with just a peice of 6 inch pipe cut in half and alittle bit of metal to box the frame in a bit.
Survivin Project is offline   Reply With Quote
Old 03-20-2007, 06:51 PM   #13
Captkaos
Captkaos's Avatar
Oops, that is what I meant. Gotta proof read these... thanks Jeff.. I corrected it...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-25-2007, 04:14 PM   #14
dacanuck
Do you have to notch the frame for a 5" flip also? Or just a 6"?
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive!
dacanuck is offline   Reply With Quote
Old 03-27-2007, 10:42 PM   #15
BaddBusa2005
so if i just do a flip on my truck, i could get away without notching the frame?
Old 03-27-2007, 10:50 PM   #16
xtreme80
Wishin' I had more money!
xtreme80's Avatar
You probably still wanna notch your frame. Even if the axle doesn't hit the frame under normal driving conditions, there's always that big bump, pothole, railroad tracks, etc. You will bottom out the axle on this stuff, and it's not fun, and could lead to damage.
xtreme80 is offline   Reply With Quote
Old 03-27-2007, 10:56 PM   #17
BaddBusa2005
tis true. thanks
Old 03-27-2007, 11:02 PM   #18
AspecialZ
AspecialZ's Avatar
"It's easier to modify now what will piss you off later!"
-quote
Jessie James
Old 03-27-2007, 11:07 PM   #19
BaddBusa2005
-quote
Jessie James
no sense in doing shizzle twice
Old 03-27-2007, 11:07 PM   #20
sighlurr
______________
sighlurr's Avatar
Here's my F150 with a flip kit.
Or wait, no, it just had over 1000 bricks in the bed.
And no people, I did not drive it like this.
sighlurr is offline   Reply With Quote
Old 03-27-2007, 11:12 PM   #21
xtreme80
xtreme80's Avatar
That's called a mexican flip kit where I come from
j/k, I'm not a racist, just see it alot in az
Old 03-27-2007, 11:12 PM   #22
BaddBusa2005
helluva kit
Old 03-28-2007, 01:45 PM   #23
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Iv donwe that before tomy old 86 c10 I was at a stop light that had a slit hill. The truck had a granny tranny so i put it in low to give it that extra goo for the wieght. Well when the light turned green my truck went up Before i started to go the truck did two full stand on the bumper. Need less to say i think that the cause of the rear going out and the tranny fork breaking off later on.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-28-2007, 04:04 PM   #24
82c10
needin' money
we put about 1500 lbs. worth of gardening dirt, and stuff in the back of mine, it had that nice flip-kit only like appearance
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 03-28-2007, 04:17 PM   #25
sighlurr
______________
sighlurr's Avatar
ttt
