#76 |
Outlandish Trends - FL
Re: progress pics
Jared, I'm definitely interested in seeing pics of that as I'm getting ready to put my 1.5" sectioned crossmember in my 67.
-Bret 67 short-fleet sold! |
#77 | |
Re: progress pics
#78 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: progress pics
Im gonna use this set-up for mine.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#79 |
Re: progress pics
#80 |
Seņor Member
Re: progress pics
Hey, don't use that set-up... I need it to steer my truck!
#81 |
Re: progress pics
hey XXL, how much is your crossmember sectioned? Do you have pics of the steering clearance "problem areas"?
#82 |
Active Member
Re: progress pics
I am going out to work on my truck right now. I will get some pics for you guys in a bit..
#83 |
Active Member
Re: progress pics
Here are f ew pictures of my steering set up. Worked great for a few thousand miles already accept for the steering shaft. It used to have a rag joint but I have since replaced it with a second u joint. My crossmember is sectioned 1.75" and my steering is raised 1.75" as well. I also lowered my cab mounts 1". The tilt column is out of an early 70's gm van and I raised it up as much as I could by cutting into the firewall. Everything works well and there are no signs of cracking...
#84 | |
Seņor Member
Re: progress pics
#85 |
Re: progress pics
XXL or anyone else who has done this crossmember mod, have you noticed any negative (or positive) effects on the bump steer? Jared, I'm sure yours is the same as before since you raised your linkage also.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#86 |
PROJECT 7DEUCE
Re: progress pics
ken you better check you ride I think you maybe missing some parts.
#87 |
PROJECT 7DEUCE
Re: progress pics
I should have the steering linkage on tonight.
#88 | |
Re: progress pics
Jared, thanks for the pics. Makes sense now. Josh |
#89 |
Re: progress pics
XXL, did you have "less" problems because you have tubulars?? Hmmmm
#90 |
Re: progress pics
OK, something else to throw into the equation. Porterbuilt moved the centerline of the front suspension forward one inch to center the tire in the wheelwell. Has anybody reinstalled their stock crossmeber forward one inch?
#91 |
Sold! 2 days after finished
Re: progress pics
I did mine 1 1/8 and I still had the problems that XXL is talking about. My bump steer is bad with out a sway bar. And there was some grinding on the X-member and steering components.
#92 |
Active Member
Re: progress pics
oh ya, I moved my motor up and forward, I dont remember how much though...
#93 |
PROJECT 7DEUCE
Re: progress pics
Looks like I have some grinding to do not bad though..
#94 |
Re: progress pics
Finished my lower control arm mod. Came out really nice. Here are some pics of each step.
#95 |
Seņor Member
Re: progress pics
You're going to want to reinforce that cardboard. Maybe some duct tape?
#96 |
Re: progress pics
#97 |
senior member
Re: progress pics
just wondering what the advantage of this was? does it distibute the force better than just welding a cup into your cut hole?
69 GMC bagged |
#98 |
Re: progress pics
Looks like the bag will sit a little lower and not rub on the control arm.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#99 |
Re: progress pics
#100 |
Seņor Member
Re: progress pics
4000+ posts and counting. Just think of all the help that's provided others *cough cough*
Arms look good, btw!
