air ride
it there a complete air ride kit out there for thease trucks ??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Re: air ride
Check on air ride technologies web site. That is where I got mine.
Re: air ride
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Questionable
Re: air ride
CPP (classic performance products) sells a kit to lower, and they have a kit from ART (air ride tech) that they can possibly include (?) in the package, or at least they can tell you which one to buy.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() Join Date: Feb 2006
Re: air ride
for a lot cheaper check out www.***************** the front mounting kit is around $50, and the rear bags are direct bolt in replacement for the springs.. you can do the whole truck for the cost of Air Ride Tech Front setup
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
#6 | |
Re: air ride
#7 | |
Re: air ride
is there a part number for the rear bags ? or a way to look up by truck type ??
Questionable
Re: air ride
You'll want the Slam Specialties RE 200's listed on this page for $75:
http://www.*****************/AirbagsSlamSpecialties.php
Re: air ride
yes.. the 7" re200's both front rear... imo i would run 3/8's bags, thats plenty fast, anything bigger is impossible to control the lift/dump
#10 | |
Re: air ride
and will thease bolt up the my frame in place of my rear springs ? can u use them as manual bags without a compressor and tank and fill them with just a regular garage compressor if i wanted to raise the truck ??
Texas Big Wig
Re: air ride
RE-7
Diameter: 7" Min height: 3" Max height: 11" Max PSI: 180 You'll need to drill mounting holes for the top, in the frame for the bolts & the air-line |
Questionable
Re: air ride
Height info ^^^
According to the other guys, these are a direct bolt-up to the frame in the rear, but you will need to drill a couple of holes for the lines going to the bag. More info is available in the last thread you started (stop starting so many threads on the same topic!! ![]() Yes to your last question also - and this was also answered in your other thread on the same topic.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-17-2007 at 12:12 AM. |
Re: air ride
