Old 04-25-2007, 06:42 PM   #1
rikyric
rikyric's Avatar
Having trouble with column and harness
I know that this is not the original harness on the column. Can someone identify it? I was looking at the harness and wiggled it out, put it back in and now my signals dont work!
Seems like my switch at the column is not working, and when I fuss with the wires that go into the harness sometimes the left and right blinkers start working.
any sugestions? here are some pics
rikyric is offline   Reply With Quote
Old 04-25-2007, 07:49 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Having trouble with column and harness
Try checking continuity? Or a little grease on the blades to help make a better contact. Check where the wires are soldered, maybe a cold solder joint.... jmho
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-26-2007, 10:54 AM   #3
Huck
Huck's Avatar
Don't recognize that column---it is not chevy truck or van for this vintage. I suppose you could wire it in but would recommend you use either crimp connectors backfilled with silicone caulk or hard solder them to avoid poor connections. Huck
Huck is offline   Reply With Quote
Old 04-26-2007, 11:15 AM   #4
rikyric
rikyric's Avatar
I figured it out last night. The harness is mechanical, it slides when the turn signal lever is moved. Is that the way 67-72 trucks are? I decided to take the harness out and install a three position toggle for my blinkers until I get new tilt coulmn that is for my truck. Anyone got a tilt they wanna sell?
