It Is What It Is,,,,
Re: Flip kit? + Shackles? How low can I go in the back.
On my 79 I had to trim the rail under the bed so that the shackle would clear.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
Dark Heart Motorsports
I use the "Toxic Shox" that I found on stylin concepts...they work pretty smooth
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
Can a leaf be added to "stiffin" up a bit?
does anyone know if any of these products work on a 3/4 ton? i have a '74 gmc 2500 and all of the parts and kits i've seen say they are for 10's and 15's.
Measure the diameter of your axle tubes. If they're 3" & the leaf spring width is 2.5", the commom flip kit should work.
how about the front end? are the a-arms and all that the same from 1/2 to 3/4 ton to allow for the same drop spindles?
nice rides guys
another question: if i use a flip kit, hangers and shackles, or c-notches will i have to lose my aux. gas tank?
yeller
I am not even sure you can do a flip, shackles and hangers without seriously modifying your frame, bed floor, and wheel tubs. It will all fit (depending on tire size), but your suspension travel will be limited with mods. It also depends on where this auxilary fuel tank is located.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
