I am trying to get my tail lights wired up so I can finally drive my truck today for the first time, but I have a problem. I have the wires from the tail lights going all the way up to the cab, but I don't remember where they plug into the cab. I can't find a connector like the one coming from the tail lights anywhere. It was four years ago that I took it apart and took pictures of everything but that pretty much...
Any description of where it plugs in or pictures would be helpful. It's a 1972 C20 350 auto. Thanks
1972 C10 1972 C20 ![]() |
Designated A-hole!
Re: Where do I find these....
Should be on the firewall to the pass. side of the steering column iirc.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
hole next to the throttle linkage on firewall.
Yeah, the hole is there...but there is no connector there. Even under the dash I don't see anything. Any idea where it's supposed to splice in to the rest of the wiring? I may just have to hardwire....
Here are pics of the holes in the firewall and the plug that I have...
TOTY 2006
![]() Join Date: Dec 1999
Should be a small round plug with 4 connectors (2 horizontal, 2 vertical) and it should be hanging under the dash. I can take a picture of the plug today if you need it..
Designated A-hole!
If I'm not mistaken it goes in the hole that you have the clear tubing running thru
just check under the dash for the same color wires then splice them in.
this should help you out. http://www.geocities.com/chevroletc1070/wiringdias.html
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
I found the problem... I had the speedo cable in the hole for the wires... I ran the speedo to the correct hole near the master cylinder(it fits much better, I'm an idiot...). The wires were jammed back behind the firewall heat/sound material. Thanks for the quick replys...
Scott
just a reminder to install a ground strap between bed and frame so your lights will work
Yep, definately need those. When I bought me '68 20 years ago, Bubba had a ground prob and drove nails between the box and frame to solve it.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
Thats a good thing to know! I think Ill go with ground staps instead of nails though.
![]() Last edited by corn; 06-15-2007 at 11:41 PM. |
Yeah, I have had some problems with my tail lights so I will have to put that ground strap in too...
