06-21-2007, 11:02 PM | #9 |
Re: Blazer driveability
The frame shop told me the frame was as good as new and it hadn't been wrecked. (frame is not cracked at the gearbox) I decided to have the pull when braking checked out. Took it to Brake Check they told me it was the power steering gear. I had one of those high/variable ratio boxes from that place in Dallas or Fort Worth (spinoff of AGR) so I changed that back to a stock box and it drives so much better, almost like a new one. It has been a long list of doing things to correct and make better, I'm not sure which took care of the problem. Probably ball joints. Been running that high ratio for a long time, before and after the ball joints so correcting one problem but had already induced another.........and on and on.......
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
