Old 07-28-2007, 06:33 PM   #1
76bonanza
76bonanza's Avatar
bouncing speedo
My speedo bounces under 20 mph then is good I just installed a new autometer speedo and it does the same? Gear in tranny? Or cable?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-28-2007, 06:53 PM   #2
cdowns
cdowns's Avatar
Re: bouncing speedo
take inner cable out clean with thinners as well as spraying the crap out of the inside of the outer vable and lube with speedometer cable lube(graphite based)
Old 07-28-2007, 07:24 PM   #3
BCOWANWHEELS
Re: bouncing speedo
all you have to do is pull the inside cable completely out, get a large tube of white lithium ( engine assembly ) grease, cut the end off the tube so it will be a small openning, squirt all you can into the outer cable where you pulled the inner cable from, then start refeeding the inner cable back in. when the inner cable pulls in the white grease squirt more into the outer cable and also grease the inner cable as you feed it into the outer cable until inner is completely back into the outer. you,l have to unhook both ends of the cable to get it back in properly. JMO
BOB
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 07-28-2007, 07:42 PM   #4
cdowns
cdowns's Avatar
Re: bouncing speedo
yeah use that white lithiam grease and in a few years just throw out the whole cable assy cause the lithium grease is petrified. and in the meantime during the winters when it hardens up just watch the speedo bounce good
Old 07-28-2007, 08:54 PM   #5
76bonanza
76bonanza's Avatar
Re: bouncing speedo
Cleaned it good and lubed it with speedo cable lube. Better, but my mount in the tranny leaks some fluid (that does not leak from the cable but from the housing correct?) Anyway the gear and cable on that end had alot of tranny fluid in it. How hard is it to change that whole housing to stop that leak (or is it an oring or something.)
1968 c10
lowered 3" 4"
