Old 06-22-2007, 12:05 AM   #26
matthufham
Re: Who's Done This
did you brace it any?
matthufham is offline   Reply With Quote
Old 06-22-2007, 01:13 AM   #27
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Who's Done This
I have two 68 hoods... i just might need to give this a try this winter. I agree with the comments about bending it toward the front and keeping it level to the back.
looks killer for a first try though. always nice to see someone jump right in and make their truck their own with no fear.
IvelDesigns is offline   Reply With Quote
Old 06-22-2007, 05:50 AM   #28
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
Originally Posted by bad6772 View Post
looks killer imo, how does it look from inside the cab?
looks good ill try and get a pic for ya
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear
1bad chevy is offline   Reply With Quote
Old 06-22-2007, 05:10 PM   #29
va_tlc
va_tlc's Avatar
Re: Who's Done This
1 bad you did a wonderful job on that man, i agree that you have some cahoonas to just jump in and start a cutting, again great job
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 06-28-2007, 07:56 AM   #30
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
to answer a few questions no there are no braces it is more solid now then it was factory as in meaning the hood does not vibrate or bounce and i only used 1 hood and had two strips cut to the size i wanted tack welded them in then trim the extra off to what you want
Old 06-29-2007, 10:31 AM   #31
1970shortbed
Active Member
Re: Who's Done This
your hood looks awesome i think i will mess with mine but keep it lower to the hood great job
couple questions
1- how wide is the cowl like how far did u measure out from each side of the center of the hood
2- how did ya form the front as in the center line of the hood that sticks up did it just bend with the hood or did ya cut it and reform it after the hood was bent up
seems like it would crinkle or fold when the hood bent up
1970shortbed is offline   Reply With Quote
Old 06-30-2007, 06:53 AM   #32
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
couple questions
i measured24 inches (12 inches from center)wide and yes you will have to notch the center right at the front and a few more to get it to bend when you do it you will see were you need to notch it i made my side pieces 5 inches high then trim the extra after you get it were you want it and you should be able to use any size sides to grt the height you want this was my first attempt at this and now i have three more to make have two sold and i need 1 more for my gmc
Old 06-30-2007, 07:15 AM   #33
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Who's Done This
that looks pretty sweet man, notice any performence difference at all? or mpg?
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-30-2007, 07:39 AM   #34
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
never thought of it i'll have to monitor that but it does seem to keep the heat down under the hood as in not as hot in the cab don't understand that but what the heck it looks good
Old 07-01-2007, 08:35 PM   #35
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Re: Who's Done This
You did a great job on this!
I love the extra tall 'Outlaw" look you wound up with.
What does it look like from inside the truck? Did you leave the back of the cowl piece open for air flow or ????
That is a true one-of-a-kind. Good onya for getting with your own idea and finishing it up.
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 07-30-2007, 05:49 AM   #36
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
yea i left it open. here is a pic of my modified dash cluster also
Old 07-30-2007, 09:07 AM   #37
CrashBob
CrashBob's Avatar
Re: Who's Done This
Like the dash. Kinda been thinking along the same lines. Much of a hassle putting it together?
CrashBob is offline   Reply With Quote
Old 07-30-2007, 01:19 PM   #38
tavenner13
Re: Who's Done This
im going to be doing an L-88 hood for my truck eventually... should look really nice considering the bulky curves throughout the body of the truck plus nobody has done it yet
tavenner13 is offline   Reply With Quote
Old 07-31-2007, 07:13 AM   #39
1bad chevy
1bad chevy's Avatar
Re: Who's Done This
it's not to bad you need to tear it all apart and do some cutting to the clear plastic face and the metal backing plate but it's not to bad
Old 07-31-2007, 10:58 AM   #40
Dad's Truck
Dad's Truck's Avatar
Re: Who's Done This
I salute any man who fabs his own parts....
Bob
Dad's Truck is offline   Reply With Quote
Old 07-31-2007, 12:21 PM   #41
OLDIRON69
Re: Who's Done This
You can buy that scoop from Summit I believe...then some glass work is involved...
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
