Old 07-30-2007, 06:20 PM   #1
68 50th
68 50th's Avatar
Engine smoking
What do you guys think the problem is with my engine.
I bought this 73 454 that was supposed to be OK a while back. Put my newly rebuilt (new guides and new teflon seals) 72 402 heads on it and yesterday I started it for the first time. It ran good but smoked from the left exhaust pipe. Then suddenly it stárted to run on 7 cylinders and a mecanical noise came on. I took the engine out of the truck and found a very oily exhaust port on #5 cylinder. Is it a bad oil ring/piston ring or what do you guys think?
Thanks in advance.
Mats.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 07-30-2007, 07:00 PM   #2
71tahoe
71tahoe's Avatar
Re: Engine smoking
The last time I had a problem like that, #1 or #3 cylinder dropped a valve. Thankfully it didn't trash the piston.
See if either of the retainer cups move side to side on #5.
With those symptoms you will have to pull the head regardless of what it is.
71tahoe is offline   Reply With Quote
Old 07-31-2007, 01:35 AM   #3
68 50th
68 50th's Avatar
Re: Engine smoking
Thanks 71 tahoe,
I will check the retainer cups.
Mats
Mats..
Old 07-31-2007, 09:23 AM   #4
Billla
Billla's Avatar
Re: Engine smoking
Did you run the engine prior to installing the new heads? Agree with checking the heads as noted...but I'd also consider a worn cam lobe (easy to check) or...the engine wasn't as OK as communicated and you've got a bad cylinder - a compression/leak down test will tell you if that's the case.
Billla is offline   Reply With Quote
Old 07-31-2007, 10:39 AM   #5
71tahoe
71tahoe's Avatar
Re: Engine smoking
Also, how did the plug look? How long did it run and what RPMs did it turn. There may be some distortion in the picture but if you hold a straight edge on #3 exhaust it looks straight. If you do the same to #5 it looks like it's bent. If the new guide was installed at an incorrect angle it could have had enough resistance to let the valve come in contact with the piston without the retainer letting go.
Old 08-01-2007, 05:38 AM   #6
68 50th
68 50th's Avatar
Re: Engine smoking
I didn't run the before I installed the new heads, and when I started it I ran it for about 5-10 minutes. All cam lobes look OK and so do the valves and the rest of the heads.
I took the whole engine apart and found a stuck oil ring expander/spacer on #5 piston.
It was overlapping at the ends and had slipped in to the slotted hole in the piston side.
The cylinder wall looks and feels OK but I will take the block to a machine shop to have it measured.
Thanks for your comments and advices.
Mats..
Old 08-01-2007, 08:37 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Engine smoking
Hey, 68 50th, thanks for the update. Too many times we have a problem and get opinions/advise and no one knows finds out what fixed it...
My 69 has been fouling the plug on cylinder #1 and I've always assumed it to be the valve guides. I may have to take a deeper look inside the tired, old 350...
68gmsee is offline   Reply With Quote
Old 08-01-2007, 09:16 AM   #8
Billla
Billla's Avatar
Re: Engine smoking
Rats The oil rings are fairly low tension, so hopefully all is well. Have to admit that I would have never suspected that...
Old 08-02-2007, 01:58 AM   #9
68 50th
68 50th's Avatar
Re: Engine smoking
I went to the machine shop yesterday to have the engine checked.
The oil ring issue on #5 cylinder didn't damage the damage the cylinder wall. We measured all pistons and cylinders. Cylinders was glazed and just honing and new rings would give to much piston play so the engine will have a 060 over bore (was 040 already) and new pistons.
Mats..
Old 08-02-2007, 08:30 AM   #10
Billla
Billla's Avatar
Re: Engine smoking
Ouch. So are you doing a complete bottom-end overhaul then?
Old 08-02-2007, 09:03 AM   #11
68 50th
68 50th's Avatar
Re: Engine smoking
Yes, I will do a complete overhaul. Bore, pistons, crank grind, all new bearings, new cam, lifters and cam drive, new oil pump and the heads was done already.
Hopefully everything turns out fine next time I start it up
Mats..
Old 08-03-2007, 07:55 AM   #12
71tahoe
71tahoe's Avatar
Re: Engine smoking
That's good to know it wasn't the heads. Is the ring gap orientation the same as when it was in the block? If so, that would be something that could have contributed to the oil ring spacer rolling in the slot of the piston. It would be something to watch on reassembly. I think they should be turned about 90 deg. from each other but I don't have my Haynes manual.
Old 08-03-2007, 09:20 AM   #13
68 50th
68 50th's Avatar
Re: Engine smoking
71tahoe, thanks for notifying me on that.
Yes the ring gap orientation was like that, I also noticed that when I took it apart.
I have the "How to rebuild Big Block Chevy Engines" book by Tom Wilson, there is a good explanation for where all the rings gaps should be.
Mats..
Old 08-03-2007, 10:20 AM   #14
71tahoe
71tahoe's Avatar
Re: Engine smoking
Looks like a PO gotcha. You know it will be right when it's finally done now.
