Junior Member
Re: GMC V-12 powered '91 Chev crewcab
Computors is something else I don't know much about.
I messed up on resizing the other pics and came up with this. Had to laugh at my own mistake, so thought I'd post it. Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. |
#2 | |
![]() [threadjack] where do the spaces go in your username? I can't figure it out so I've been calling you crouton. ![]()
-Jake 1962 ![]() ![]() Interior- Puke green dash, brown vinyl seat from an 87. Exterior- Rust 1993 ![]() If you have a truck everyone is your friend. When they need to move. |
1961 crewcab
2 ideas on the radiator/hood interference...
I didn't see how it was mounted, and what the fan/shroud clearance would be... the ideal thing would be to just drop the radiator down just the 3.5 inches, it looks like there is plenty of room underneath. another thing you could think about is a body lift, leave the radiator where it is, and space out all the body mounts 3.5 inches, like they do on 4wd's, that would lift up your body high enough to get the hood to close. with a body lift you might run into issues where you need to lengthen , or move linkages that come from the body- clutch,brake line,gas pedal inkage, steering column. |
think it will fall in the hot rod catagory when you make it real nice and paint it or rad rod if you leave it as is
jonz : i think the radiator is wider than the framerail so it cant drop between them
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-20-2009 at 11:41 PM. |
Looks like you've been busy, that thing is looking good. I wonder if a radiator from a 70's / 80's vintage 454 truck or RV with the HD cooling / tow package would work. I bet there are plenty of 'em in the yards now days.
'50 GMC 350 COE, 702 V-12 / 4L80E powered '71 GMC 6500, 427, 5 spd |
Junior Member
This radiator is narrow enough to go between frame rails. Bottom of radiator is even with bottom of frame now.
Fan clearance is the problem. Any lower and fan will hit top tank and shroud. No problem to drop by using electic fans. Coolant capacity with this radiator now is 17 gallons. Kevin, when you gonna' post your "masterpiece"? Cayoterun
1961 crewcab
Is there a way to mount the fan to the crank pulley instead of the water pump pulley?
that would buy you some room... |
Junior Member
I did some measuring today.
Fan on crank won't work. The radiator would be faar too low to line up and below front suspension. I'm trying to avoid more body lift if possible. My hinges are alot rustier now than 25-30 yrs ago. I don't bounce in and out of trucks as easy now. This radiator can be dropped up to 5". The bottom hose would be a little close on room, but doable. It would need a rock screen in front of the lower part. It would be below the bumper some. The shroud would be discarded and use electric fans. The cooling surface of tubes is 26" X 26". I'll do some checking measurements on truck radiators, such as 454s, diesels, and road trucks too. I did get the bed BOLTED down today. Much easier to take off if needed. Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. Last edited by cayoterun; 01-21-2009 at 10:04 PM. |
Here ya go Cayoterun. Just finished the front motor mount about 2 hours ago.
Junior Member
Waay to go!! Even got the tranny mounted or is my eyes doin' tricks?
Good to see your progress. Thanks for posting it. Cayoterun
now THATS the way to mount that engine
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
Junior Member
I knew this was being done, but wanted to wait and let Locomotive post when he was ready. He already has a Sherman tank engine installed in a Mustang, and it's posted on U-tube. We're trying to use a little different application for the V12s.
There are two other V12 projects out there being worked on also. We'll see what they come up with. Most of you guys ideas are being used in some way somewhere on these 4 projects that I know of. Thanks, Cayoterun
i've seen that sherman mustang sounds awesome , was a pretty advanced engine even by todays standards
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-26-2009 at 06:54 PM. |
Junior Member
It's getting the farmer look. Already junk on the bed. Couldn't wait for son to come in off road to video first move. It will now "Whoa and go".
Ran it for about an hour, temp set on 180, oil pressure at 40 pounds. Brakes work ok. Only putted around here in yard and out in the pasture some. Lower pic shows 6" clearance between rear motor mount and oil pan we ended up with. Someday running board might hide that some. Still have to be careful over humps. May post video over the weekend. Won't show much, but it's proof IT MOVES. Cayoterun
#15 |
DON'T TREAD ON ME
![]() Join Date: May 2005
![]() EDIT: While I was studying the photo of your truck I noticed the surrounding plains looks exactly like West Texas where I live. But I thought that would mean you have to live due north of me in the OK panhandle. I live 4 1/2 mi SE of Ralls, so I decided to look you up and guess what? ![]()
Old Yeller Last edited by Old Yeller 1970; 01-30-2009 at 08:33 PM. |
#16 |
Junior Member
Well, Hello neighbor:
We attended the funeral for a relative of my wife at Wolfforth not long ago. Heck, If the pic had been taken to the south, as treeless and flat as it is out here, it might show your place. It's only about 300 miles. Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. Last edited by cayoterun; 01-30-2009 at 09:03 PM. |
#17 |
DON'T TREAD ON ME
Yeah, this is the view north from my place. I believe I can just make out your place on the horizon.
Old Yeller |
#18 |
Junior Member
I thought "Balaur" deserved to wear her V12 badges today. Thanks, Bob W. After 17 months of work, she will Whoa and Go. Here's proof.
Lots of work still to do. I want to thank all of you who have offered advice and suggestions on this. The project has taken many unexpected forks in the road due to them, but have acheived more than I set out to do. The result is more than I had expected. I'm sure that if any ever meet her in person, you will recognized your ideas. She looks alot better in the pics than in person. The noise on the video is our ever present Okie wind. Thanks, Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. Last edited by cayoterun; 01-31-2009 at 07:12 PM. |
#19 |
DON'T TREAD ON ME
That's awesome. I love how it sounds. A couple of my boys even came running in to see it when they heard it playing over my computer speakers.
Old Yeller Last edited by Old Yeller 1970; 01-31-2009 at 08:28 PM. |
#20 |
I LIKE IT!!!
Something you might want to consider is power steering.My arms hurt just watching you steer that thing!(I have it on my 351 v-6).I see you've done a lot to it that you didn't mention in your posts. I bet it would do well at the tractor pulls! And thanks for the videos---Makes it real for us out here! Mike. ![]() ![]() |
#21 |
Great video Cayote! Been watching your build 'from afar'. Cool to see it moving under it's own steam. Must be fun to be drivin' it round finally.
Bill.
1972 K2500 Long Box 400/350 |
#22 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#23 |
Great to see it moving with V12 power, good job.
#24 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
If Chuck Norris needed a motor for his truck, thats the one he'd put in...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#25 |
![]() ![]() Join Date: Dec 1999
Holy crap is that cool.
Gas guage moves faster than anything i bet......
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
