Old 09-10-2015, 01:02 PM   #1
Low Elco
Re: '67 Short Step #2
Hope so- I wanna see it!
Low Elco is offline   Reply With Quote
Old 11-05-2015, 11:59 AM   #2
mahanian
C10 addict
mahanian's Avatar
Any updates?
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 05-05-2018, 12:21 PM   #3
kyull67
kyull67's Avatar
We're Back!
The last few years have been full of life changing events and circumstances and the truck has been kept mostly tucked away in a dark dusty corner.
I've made a few small improvements to the interior lately and had a new set of tires installed. This past winter fellow board member Robert aka Bobbo made a weekend road trip to help with the install of a new camshaft. I chose a Comp Cams turbo grind camshaft by Tom Lowe @ www.12bolt.com
Another friend and I finally backed the truck out last night for yet another first start and break in. I posted the link to a short video of the break in below. Make sure your volume is turned down..
https://youtu.be/MK0jXJTnb8A
kyull67 is offline   Reply With Quote
Old 05-05-2018, 03:33 PM   #4
Good to see ya and the ole girl back in action.
I guess I need to reread all your build since I got a 6-banger now that will need a few tweaks.
Old 05-07-2018, 10:37 AM   #5
kyull67
kyull67's Avatar
Thanks.
This book and www.12bolt.com are what you need to build a performance inline six.
https://www.amazon.com/Chevrolet-Inl.../dp/1931128278
Old 05-07-2018, 11:23 AM   #6
Low Elco
Glad to see you back in action! Hope to see you in September!
Old 02-19-2020, 09:51 PM   #7
kyull67
kyull67's Avatar
Haven’t had much run time since the last update but I keep having bad luck with machinists and cylinder heads. Decided this time instead of removing the head bolt boss in the intake ports I’d grind them into a wing shape and go with bigger valves. 1.94” intake and 1.6” exhaust. Also pulled the engine to replace the rear main and gave it a fresh repaint. Oh and also picked up a 292 for later!
Old 03-03-2020, 10:56 PM   #8
kyull67
kyull67's Avatar
Got it all back together with a couple changes. Using a 5 pin ignition module from an 80’s GM HEI with spark control and a Hobbs switch to pull 10* of timing when the intake is pressurized. Also installed the Innovate SG1 boost controller with map sensor and wideband. It has the ability to change boost levels from the dash and also cut boost under rich or lean conditions. Painted it to match and installed under the cluster. Also got and new tailgate from Mak-k. I’ll post some pictures of the painting and finishing of that later.
Old 03-03-2020, 11:08 PM   #9
kyull67
kyull67's Avatar
Old 03-08-2020, 11:13 PM   #10
Kronald_70GMC
Kronald_70GMC's Avatar
Just finished reading your whole thread. Very cool truck! I like that you are keeping at it with the Inline 6. Always good to see so many diffrent trucks on this forum. Such a vast collection of knowledge, skill and information! Keep at it and hope you are back on the road again soon.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 03-10-2020, 02:41 PM   #11
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I see you list Springfield/Kansas City. I'm in Springfield. Would love to see you project if you are close.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 10-12-2020, 03:12 PM   #12
kyull67
kyull67's Avatar
Thanks! We’ll have to get together sometime down there. Quite a few board members in the area. Looked at your build for the first tine today, very nice!
Old 10-12-2020, 12:25 PM   #13
kyull67
kyull67's Avatar
Finally got it out and drove the truck several miles for the first time since like 2010! I’ll try to post some videos later.
Old 10-12-2020, 01:24 PM   #14
Glad to hear you got it out again.
Old 10-12-2020, 02:54 PM   #15
kyull67
kyull67's Avatar
Links to some videos;
https://youtu.be/paJVCochDhU
https://youtu.be/pCviOfr7DBk
https://youtu.be/Dsstp0MS-NY
https://youtu.be/iBjrQey1Hiw
Old 10-12-2020, 10:13 PM   #16
chewychevy67
I like the sound of that engine.
chewychevy67 is offline   Reply With Quote
