Old 01-02-2003, 10:39 AM   #1
MStokes
MStokes's Avatar
Rear Coil Spring
This is a photo of my rear coil spring. When I got to looking at it I noticed that the wraps in the coils are closer together in the center of the spring. The other side is the same way.
Is this normal for a stock spring, or was is lowered at some point by heating it?
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 01-02-2003, 10:46 AM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Looks like it was heated to me. My stock coils did not look like that.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-02-2003, 10:49 AM   #3
MStokes
MStokes's Avatar
Is there a way to measure the stance of the truck like dimensions from the ground to the high point on the fender above the wheel?
This truck is a 72 C10.
Old 01-02-2003, 11:21 AM   #4
jmil1974
Ain't we cute?
jmil1974's Avatar
I would have to guess lowered too. My springs don't look like that either.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 01-02-2003, 11:24 AM   #5
1971Stepside
Almost Satisfied
MStokes, this would be possible I just can't help you since my truck is just a frame right now. I'm sure someone on here can post stock height measurements for you. Do you want it stock or lowered?
Old 01-02-2003, 11:28 AM   #6
MStokes
MStokes's Avatar
I'd like to find out what stock is so that I can compare it to what my truck currently sits at. I think I want to go with a 2.5/4 drop on it but want to make sure I don't mess up the driveability of it with wheel clearances and handling.
It would help to know if any of the previous owners did anything to change the stock height of the truck.
Old 01-02-2003, 11:28 AM   #7
JQ-72
JQ-72's Avatar
Your springs are what Chevrolet advertised as two-stage design on all 10 and 20 series. Here is a quote taken from a '65 dealer brochure :
"Coil-spring rear suspension for series 10 and 20 gives superior ride and load control because of its special two-stage design. A single set of springs gives softness for smooth ride when lightly loaded, plus firm control for top payloads and extra duribility. Two stage action is accomplished by reducing the number of active spring coils as load is increased. Closely spaced central coils (see left) close and become inactive under moderate loads, giving extra spring stiffness and firm load support."
It shows a picture of the coil spring with the closely spaced central coils. Hope this helps!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 01-02-2003, 11:31 AM   #8
MStokes
MStokes's Avatar
That helps a bunch. Does it say if all 72's with coil rear ends came with these springs, or was it some kind of option?
Old 01-02-2003, 11:39 AM   #9
JQ-72
JQ-72's Avatar
These two stage springs were used from the early 60's until 72. I just double checked a 72 brochure and it mentions two-stage design also. This was not an option. All coil rear trucks had them.
Joshua
Old 01-02-2003, 11:46 AM   #10
jmil1974
Ain't we cute?
jmil1974's Avatar
Wow, I guess when my uncle said he changed to C20 rear coils -- he meant it.
FOR SALE $3900
Old 01-02-2003, 11:55 AM   #11
1971Stepside
Almost Satisfied
Mine was a c10 with original springs and it did not have them....hmmmmm
Old 01-02-2003, 11:56 AM   #12
slam33
slam33's Avatar
My 3/4's are like that
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 01-02-2003, 12:00 PM   #13
crazy longhorn
Fabricate till you "puke"
the coil trucks that I have had were wrapped tighter in the center.......I wouldnt doubt that your springs are sagged from 30+ yrs of use tho.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-02-2003, 12:05 PM   #14
cnshoot
cnshoot's Avatar
there are diff springs for diff apllications some have them some dont but they are stock with the heated center. it was for the ride of the truck. one side of the spring would take the weight and the other would take the ride so thus a load and smooth ride
cnshoot is offline   Reply With Quote
Old 01-03-2003, 12:35 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have never seen a rear coil that was not like that.
Old 01-03-2003, 12:49 AM   #16
1971Stepside
Almost Satisfied
I would love to show you mine, but they are now in the local landfill. Hmmm, let me dig around...I may have a pic of them during the disassembly. I may be wrong, but I sure don't remember them looking like that.
Old 01-03-2003, 12:55 AM   #17
1971Stepside
Almost Satisfied
Hmmmm
I think I stand corrected, but this is a bad pic to tell from. It looks like the right one is that way but the left one is different. Who knows and you guys are the experts...
Old 01-03-2003, 03:20 AM   #18
orange72
orange72's Avatar
ive never seen a stock coil like that either...those center coils are usually close together but not that close. on my truck the previous owner lowered it by heating them up and it sure rides rough. my springs also look something like that too. but i may be wrong. ill go look at one of the trucks in the field to see tomorow.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 01-03-2003, 03:41 AM   #19
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
The coils in my 70 were like that also. Mine weren't heated up they were just pure junk after 30 plus years of abuse. My uncle had my truck for the past 12 years drove it everyday and towed all kinds of heavy equipment with it. Oh...My truck also shows an option for HD rear coils. I went with a 2/4 drop with mine it rides like a new truck compared to how it used to with those old coils bottoming out all the time!
Hotrod70C10 is offline   Reply With Quote
Old 01-03-2003, 04:10 AM   #20
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
All panel trucks of that era had non-progressive rear springs, these were the only model that way. I do not know why. ECE springs are straight wound, also.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 01-03-2003, 10:50 AM   #21
da-burb
"Ochre Ogre"
da-burb's Avatar
Mine are just like the ones in your picture. They are just a few years old and were called "variable rate springs" in the catalog.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-03-2003, 11:11 AM   #22
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
During the time I was laid off from my "good" job in the mid-70's, I was forced to find other work....which I found at "the world's largest department store auto center".
I changed enough shocks to have seen both types of springs that you have all mentioned. I recall seeing those springs on the 3/4-tonners. Half-tons could have either. My '69 had extra capacity springs. i.e., 2000-lb option, and had them, too. This is on a short wheel base truck. So, you KNOW I had a rough ride until I changed them and lowered it. Still got the hitch, tho.
Member Nr. 2770
Old 01-03-2003, 04:45 PM   #23
BobM
Question
The originals in mine were of the same design. Put in in a new set which are called "variable ride". The coils are closer at one end than at the other end. Only question I had about them is "what is the proper way to put them in?" Do the closer wound coils go at the top or bottom? Haven't found anyone that can give me a definitive answer. Any of you guys want to give it a shot???
BobM is offline   Reply With Quote
Old 01-03-2003, 05:18 PM   #24
1971Stepside
Almost Satisfied
BobM, if you look at the picture of my frame (when it was ugly) up above you can see the passenger side spring seems to have the tighter wound coils at the top. I don't know if that helps or not. You might be able to tell by the way the retainer cups fit?????
Old 01-03-2003, 07:19 PM   #25
greasemonkey
greasemonkey's Avatar
Mine look like that.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
