Old 11-07-2007, 06:57 PM   #1
oldsmobilekindofguy
I already busted a couple knuckles what is the trick?
Man they really made the front bumper on my 67 C-10 nearly impossible to take off. The top bolts are too cramed to get a socket in there and the nut is in the braket that is U shaped so a boxed end won't fit, is there a trick to it or something, the front bumper on the 70 delta was simpl;e to take off, this one sucks
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 11-07-2007, 07:10 PM   #2
DavesRide
DavesRide's Avatar
Re: I already busted a couple knuckles what is the trick?
I have had problems with those and the ones holding the bed on. I got after them with a die grinder on which ever side was easiest. If you grind the bumper bolts off from the front keep a steady hand and keep the wheel perpendicular to bool head. Sometimes you don't have to grind it all the way off. Get it so thin and then punch it on through. A cutting touch will make very quick work of removing the nuts also if you have one at you disposal. Dave
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 11-07-2007, 07:25 PM   #3
oldsmobilekindofguy
me with a grinder would mean grinding marks all over the front bumber and on the chrome, But I did a search and found an idea that will work but it is to easy for me to think of, JUST REMOVE THE BRAKET FROM THE FRAME
Old 11-07-2007, 07:27 PM   #4
oldsmobilekindofguy
grinding was my next option though, thanks for the advice
Old 11-07-2007, 07:59 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
You came up with the same idea as me, I removed the bracket from the frame too, after a few hours of cussing first
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-07-2007, 08:33 PM   #6
wibilly
wibilly's Avatar
if you wanna know the easy way to do somthing ask a lazy man
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-07-2007, 08:37 PM   #7
BCOWANWHEELS
unbolt the hole bumper assyembly from front of truck then heat the nuts from the back side and hit em with full air power on a impact wrench
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-08-2007, 08:34 AM   #8
oldsmobilekindofguy
thanks for all the help, maybe I don't need to, I am taking the pass. side fender off because it is junk and i am tryiung to get at all the spot welds, I think I have to take off the front bumper but how about the front grill piece, does that have to come off also?
Old 11-08-2007, 09:14 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah, the easiest way to take the bumper off is to take the top L shaped bracket off with it. It has a nut welded to it, so it's easy to get the bolt out (if it's not rusted up.)
Take off the headlight bezel and there will be 6 bolts holding the grill to the fender. 3 on the top, 3 on the bottom. They're a pain in the but to get too. It's easier if you pull the headlight out too. Just push the plastic adjusters away from it and then the spring should come out pretty easy. Hope that helps
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-08-2007, 12:03 PM   #10
Mt Man Chad
Mt Man Chad's Avatar
Spray them down with "PB Blaster" and let them sit for a day or two then they should come off easy!
It's what I use at the local junk yard and it usually work in minutes!
The stuff works the best hands down to any other bolt buster!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 11-08-2007, 02:13 PM   #11
smoked68
smoked68's Avatar
I use an open end finagled in there and a box of band aids and neosporin. Works fine............
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-08-2007, 04:43 PM   #12
chip46wis
I just removed the front bumper from the 71 Im parting----the easiest for me was to use a breaker bar and tighten them until they snapped.Usually 1---1 1/2 turns.
chip46wis is offline   Reply With Quote
Old 11-08-2007, 07:10 PM   #13
oldsmobilekindofguy
haha thanks for all the help
Old 11-08-2007, 08:33 PM   #14
Big Block
Big Block
Big Block's Avatar
I have done that a time or two. Works better than having busted knuckles. New bolts and your done with it.
Big Block is offline   Reply With Quote
