11-15-2007, 12:39 AM | #1 |
Seat Belt bolt holes?
I need a small favor from someone. I had to replace so much of my floor, that somewhere in the shuffle I forgot to put in seat belt holes. I have the ones for the center belt and inner buckles, but I need the ones for the outer driver passennger parts. Can someone please measure from the back of the cab wall and from the door weatherstrip or something for me please? Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
11-15-2007, 06:47 AM | #2 |
sufficiently talented fool
Re: Seat Belt bolt holes?
The seat belt bolts to the rear cab support. There is a welded nut on the front edge of the support. Look underneath the floor and punch the hole from the bottom.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
11-15-2007, 10:52 AM | #3 |
On the fast track to nowhere..
that's how I did my last set.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
11-15-2007, 04:08 PM | #4 |
I replaced the floor and the rear cab supports, so right now there is nothing... The nut was actually broken off originally from rust.
11-15-2007, 04:19 PM | #5 |
OIC. If no one else does it I'll measure mine when I get home.
11-15-2007, 06:41 PM | #6 |
OK. Mine are 6 3/4" from the back wall and 2" from the inside of the weatherstrip flange, both sides.
11-16-2007, 12:46 AM | #7 |
Thanks man! That's in the area I figured, but now I know for sure. Carpet will go in ASAP now.
