Old 11-15-2007, 06:11 PM   #1
Eric M.
Want to bolt a 73-87 style P/S box to a 64 GM
I wonder if anyone has done this or if there is a kit out there.
My buddy has a 64, 1 ton, 2wd Chevy. He is converting the front end over to the 73 - 87 suspension, brakes and steering. Most is bolt on, but not the steering box. His present set up is a manual steering box and the frame is missing the contours of the later style frame which allows the power steering box of the 73 - 87 vintage to bolt up.
Anyone have any ideas? Any kits out there that would do the trick?
Thanks,
Eric M.
Eric M. is offline   Reply With Quote
Old 11-15-2007, 10:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Want to bolt a 73-87 style P/S box to a 64 GM
Some people heat the frame and indent it and some people make a set of spacers to go between the box and the frame for clearance. If you use the spacers make sure the longer bolts are grade 8...
LockDoc
Leon
Old 11-16-2007, 12:09 AM   #3
Eric M.
Thanks LocDoc,
Any preference to which method might be better. I hear heating the frame makes it brittle, but spacers can't be as solid a connection as bolting directly to the frame?
Have others welded the spacers to the frame?
Thanks,
Eric M.
Old 11-16-2007, 09:43 AM   #4
jerry moss
Born Psycho
jerry moss's Avatar
we built a 63 4x4 for my nephew and used an intergal box off a 70 up 4x4. we machined spacers for the outside AND used a section of another 69 up frame on the inside of his frame. we also used a 69 up steering shaft with the flexible joint instead of the solid oem shaft.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 11-16-2007, 11:50 AM   #5
Eric M.
That might be the way to go, graft on a section of frame from the 73 - 87 style trucks.
Someone on CK5 mentioned a kit but couldn't remember who made it. Anyone ever hear of such an item?
Thanks,
Eric M.
