blazer tank in the rear ?
how far does a blazer tank/sub tank hang down? any good pics of one installed on a fleet side? Iam concerned it look like it will hang down alot.
Re: blazer tank in the rear ?
Mine's not too bad. At stock ride height it doesn't hang below the third member, or the trailing arms. And plus that, I'm gettin' ready to drop her 3" too. I don't foresee any problems with that either. I suspect, w/o doing any looking, mine still won't hang below anything else.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
What is the capacity on the blazer tank?
1969 C10 Stepside, 350ci, 700R4 |
