Old 12-03-2007, 08:13 AM   #1
OhNoJoe
OhNoJoe's Avatar
4200 Inline 6
Has anyone taken one of the newer inline 6 cylinder emngines and dropped in a 67-72?
i'm thinking I might try it if it isn't too much of a hassle. There are some posts of the straight 6 web cites. But this is the source!!!
Any thought would be helpful
Joe
OhNoJoe is offline   Reply With Quote
Old 12-03-2007, 09:36 AM   #2
Konk
Re: 4200 Inline 6
My mom's Trail Blazer uses that engine, and I can tell you it's great. Plenty of power in that thing, smooth; it would be perfect for a old C10. Can't help you specifically, but I'd love to see somebody put one of those in a old truck!
Konk is offline   Reply With Quote
Old 12-03-2007, 10:20 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: 4200 Inline 6
I also would like to see if someone will do this.
However, I think the only reason someone would do this is to try to get better mpg. The power, availability of parts, and all of the options and versatility of a 350 still make it a better option for horsepower.
My Trailblazer gets app 20-21 mpg on the highway depending on wind, a/c use and terrain. But in town, it drops down to about 15-16 mpg. I don't thing it would stay the same if we dropped it in one of out non aerodynamic, built for work trucks.
Still, I believe someone will do it just to be different and "because they can."
68gmsee is offline   Reply With Quote
Old 12-03-2007, 10:36 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 4200 Inline 6
My trailblazer got around 9 in town and 15-16 on the highway . I was not very happy with the 4200 I-6 . Just my opinion.
hotrod 80 is offline   Reply With Quote
Old 12-03-2007, 11:00 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Re: 4200 Inline 6
Ouch! What year was yours? Mine is a 2006. It's pretty consistent on the highway mileage but I've only checked in town mileage one time. I think where you live may make a lot of difference. Not much traffic around here.
To be honest, I think the I-6 swap may be a better option if you already had the engine and transmission plus all associated wiring from a wrecked truck.
Old 12-03-2007, 02:38 PM   #6
tkeduk8r
tkeduk8r's Avatar
Re: 4200 Inline 6
I agree, I belive the 4200 is a different critter other than 6 cylinders in a row vs the 230-250-292 versions... not much would bolt up as far as intake, exhaust, etc.... BUT that being said, if you can weld and have access to a few basic machine tools, I belive it could be doable.... Distributor less ignition would be the biggest challenge I would think... JMO...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-03-2007, 04:17 PM   #7
69halfton
69halfton's Avatar
Re: 4200 Inline 6
i dont know what I-6 you guys are talking about...
chevy makes an I-5 in their new colorados, but they dont put them in any trailer blazers i know of.
i know of a 4.3 V-6 that goes in trailerblazers?
...ive herd that the new I-5s with mods are "small block killers" with tons of torque...could be very cool
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 12-03-2007, 04:32 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 4200 Inline 6
Mine was a 2003 4x4 . The 4200 is the same as the I5 + one cylinder . The 4,5, & 6 cylinders share alot of common part . I did alot of research on these before the purchase . I work with a guy that has a 2003 with 5.3 V-8 and his always got better mpg . These motors with a turbo set up make killer power . I just wouldn't go through all the work to swap one in . A 4.3 tbi on an inline 250 would seem like a better swap . I did this on a Jeep 258 I-6 and it really woke it up . Again this is just my opinion and probably infuenced by a bad experience with the Trailblazer .
Old 12-03-2007, 07:45 PM   #9
jorgensensc
jorgensensc's Avatar
Re: 4200 Inline 6
Something was definately wrong then. We have an '06 TBSS with the 6.0 V8 and I consistently get 14.1 MPG. And you know I have my foot in it 90% of the time. It doesn't have the weird demand thing that turns off half the cylinders either.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-03-2007, 09:37 PM   #10
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: 4200 Inline 6
They have never put 4.3's in Trailblazers. They put the 4.3 in Blazers. The 4200 L-6 came out a long time before the I-5 and I-4's in the Colorados. The 4200 has been being produced since 2000, and the original version was 270HP. The latest version is 285HP. These things run really good for what they are.
Vortec 4200 I-6 Engine
Standard in TrailBlazer LT models, the Vortec 4.2L I-6 engine generates 285 hp — unsurpassed in its class(1) — at 6000 rpm and 276 lb.-ft. of torque at 4600 rpm.
Some important features of the Vortec 4.2L I-6 engine:
A broad torque curve through the majority of the speed range helps this engine deliver 90 percent of peak torque from 2000 to 6000 rpm. This provides ample torque at low rpm and high rpm, giving you an SUV that responds with the torque you need, when you need it.
Electronic Throttle Control (ETC) relays accelerator pedal position information to the Powertrain Control Module (PCM). The PCM then positions the throttle air valve in the best position to help achieve optimum vehicle drivability.
Pistons and rods are lightweight, helping this engine run comfortably at high rpm and producing more power from smaller displacements.
Variable Valve Timing offers a number of advantages over conventional valve timing in the areas of power, efficiency and emissions and helps produce near-peak levels of torque over an extended range.
An advanced heat treatment process give the aluminum engine block and cylinder heads light weight with exceptional strength.
Nodular iron crankshafts were optimized using the most advanced math-based computer tools available to GM to help provide quiet operation, long-term reliability and remarkable durability.
Iridium-tip spark plugs help this engine travel up to 100,000 miles before the plugs need to be replaced. The recommended engine coolant change interval is up to 5 years or 150,000 miles, whichever comes first. And the accessory drive belt is designed to operate up to 150,000 miles before requiring replacement. Maintenance needs vary with different uses and driving conditions. See the Owner’s Manual for more information. See your dealer for the Chevy TrailBlazer maintenance schedule.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-03-2007, 09:39 PM   #11
67_C-30
67_C-30's Avatar
Re: 4200 Inline 6
BTW, the base model Trailblazer weighs 4350, so this engine would do OK in our trucks despite the non-aerodynamic styling.
My trucks
Old 12-03-2007, 09:48 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
Re: 4200 Inline 6
I knew these things had a real nice torque curve but I had no idea they were that good. 276 lb-ft@ 4600? that variable cam timing really pays off. they can now get the combustion pressure up there without the worry of burning a piston AND they can go without an EGR.
68C15 is offline   Reply With Quote
Old 12-04-2007, 12:23 AM   #13
Ackattack
Ackattack's Avatar
Re: 4200 Inline 6
when I get done with my 68, my wife wants a nova....so I'm going to put a 4200 I6 in there.....with a hair dryer!
Ackattack is offline   Reply With Quote
Old 12-04-2007, 08:44 AM   #14
Re: 4200 Inline 6
I don`t see a huge difference in aerodynamics between a Trailblazer and a 67/72,other than the rain gutter.
Old 12-04-2007, 10:51 AM   #15
69halfton
69halfton's Avatar
Re: 4200 Inline 6
hmmm i thought that there were definatly V-6s in the trailblazers...
maybe in canada they are different?...alothough i doubt it.
Theres a racing class at the local stock car track here that runs Hopped-up I-6 motors, and they sound awsum. ive always thought itd be cool to have a totally stock I-6 truck, and have it look normal. but then you start it up and fry the skinny tires all the way down the street
- Jason
Favorite caption:
Old 12-04-2007, 02:52 PM   #16
dwaite72lnghrn
Re: 4200 Inline 6
I like the 4.2 I6 we have in the 2002 trailblazer. On a trip out west we got as high as 25mpg and in the mountain passes around wolf creek, Durango and Cortez we got about 21mpg. They are computer controlled and I think drive by wire also. Around here low mountains and hills we get about 19-20 daily.
I think the first year trailblazers were the old s10 type with the 4.3l engines.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 12-04-2007, 05:03 PM   #17
OhNoJoe
OhNoJoe's Avatar
Re: 4200 Inline 6
With the drive by wire then you got to goof around with the pedal arangement????? Plus I would have to get all the puter stuff for it and find nice mounting spots. I'm guessing it's not any different than putting a newer 350 with IF into on or these truck... Might even be cheaper than building up a 72 292.
Old 12-04-2007, 09:09 PM   #18
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Re: 4200 Inline 6
It's either that or a Diesel for me when I'm done. I want economy and mild towing capability. That thing produces more power and torque than my old worn out 350, costs about the same as a rebuild, and won't leak or have a choke. They are good engines. If I can get 17 with the 350 I am sure the 4.2 will bring me into the 20's. You're forgetting something comparing the Trailblazers with these trucks - Trailblazers are HEAVY.
The only thing I don't like about the I-6's is that (I think) the four wheel drive versions have the half shafts coming out of the oil pan... yeah that's what I meant.
I still want one.
Bottom line - it's your truck. Put a 4 banger turbo dodge motor in it if you want.
-Brian
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 12-05-2007, 07:50 AM   #19
OhNoJoe
OhNoJoe's Avatar
Re: 4200 Inline 6
Here is the most complete write I have found for this swap. It seems too hard for me to do. This guy and to fab up an oil pan get a different IF system different motor mounts.
http://www.inliners.org/cgi-bin/ulti...=001014#000000
I just used the search feature at inliners.org term 4200. I might be able to find some more stuff.
It would be great to find someone here who has done this swap.
Old 04-02-2008, 11:53 AM   #20
RamAirZ
Re: 4200 Inline 6
There are a few guys I've talked to that have done this swap, a few are building turbo setups. I had planned on doing this swap into my 69' pontiac but decided against it due to what I wanted the car for. I have an exhaust flange for the 4200 if anyone wants one lol
1967 Chevy K10- 4WD project in the works -sold
1985 Suburban- 1/2 ton w/ 3/4 ton gear, 350/700R4 33's and big!
1987 Iroc- LS1/T56 conversion- sold
RamAirZ is offline   Reply With Quote
Old 04-03-2008, 04:30 PM   #21
OhNoJoe
OhNoJoe's Avatar
Re: 4200 Inline 6
I got the 4.2 but now that I'm looking at it it seems a bit more than I can handle I think I'll go back to the 292 I got everything I need for that ps/ac...ect ect ect.
I'm trying to selling 4.2 for what I got into it. I had it on ebay for $250 All I got was nine lookers and no bids.
Old 04-03-2008, 05:02 PM   #22
Bowtie001
Bowtie001's Avatar
Re: 4200 Inline 6
I might be interested in it depending on what accessories you have with it and price and location, of course. PM me if you're interested in selling.
-Brian
Old 04-03-2008, 10:25 PM   #23
RamAirZ
Re: 4200 Inline 6
It's fairly easy to swap, the wiring is pretty straightforward especially if you use something like Megasquirt to control it
Old 04-04-2008, 07:42 AM   #24
Deuce
Deuce's Avatar
Re: 4200 Inline 6
There is a guy (efi-diy) the was looking into a carbed version of the 4200 on www.performance-shop.com
Send him a PM maybe if interested.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-04-2008, 09:26 AM   #25
tdave00
Restoring a 68 SWB
tdave00's Avatar
Re: 4200 Inline 6
I have never gotten my password for inliners so I haven't been able to view those posts. Why is the swap so difficult?
tdave00 is offline   Reply With Quote
