Old 01-06-2003, 10:24 PM   #1
Stroker
Question Minimun Ride Height
Was wondering how low these trucks can be and still be driveable. It seems that with a conventional type suspention (coils,and dropped spindle) a 4/6 drop is all that the chassis will tolerate without screwing up the front end geometory. Is it possible to add a 1-2 inch body drop without having a lot of problems. I'm wanting to have a stance that will tuck the front tire a little. Was wondering if any of you guys with adjustable suspentions had pics of your min ride height and what special mods if any you needed to prevent tire clearance problems. Thanks.....Stroker
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 01-06-2003, 11:10 PM   #2
crazy longhorn
Fabricate till you "puke"
I have a 3/5 drop, with an 1 1/2" of body drop. the front tires are tucked in the fenders just a little. I couldnt say how far you could go with inners fenders(tilt front end), but without I could go a little more. I think 2" on the spring, & 2 1/2" on a spindle is about alll you could go & really keep the geometry good. a little body drop on top of a 4/6 will get it down.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-06-2003, 11:24 PM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Hey crazy longhorn where did you get your body drop kit and how much was it?
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 01-06-2003, 11:27 PM   #4
crazy longhorn
Hotrod,that was all fabricated....didnt cost too much,but lots of welder burns
Old 01-06-2003, 11:28 PM   #5
SCOTI
SCOTI's Avatar
My beater is 5/7" drop w/15" steelies & daily driven. Up front 2.5" Western Chassis spindles + 1 full coil cut from factory springs, & out back air bags, 1.5" blocks + adj panhard bar & bolt-in c-section. After 2.5yrs the wood floor directly above the pumpkin is pretty well gone (not that it was in good shape to begin with) & the driveshaft has actually hit the top of the driveshaft hoop hole a couple of times. Oh yea, I pull a 18ft car trailer @ least once a month.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2003, 07:40 PM   #6
Stroker
Thanks for the input guys. I was thinking of raising the bed floor and rear wheel tubs a couple of inches just incase I decide to bag it in the future. Crazy longhorn, how much work is actually involved in doing a mild body drop? So do you think a stance like this is possible with a 4.5 / 6.5 drop combined with a 1 to 1 1/2 body drop. Thanks....Stroker
Oklahoma
Old 01-07-2003, 07:42 PM   #7
Stroker
Ops forgot the pic.
Oklahoma
Old 01-07-2003, 07:48 PM   #8
Stroker
Ops forgot the pic.
Oklahoma
Old 01-07-2003, 08:17 PM   #9
crazy longhorn
Stroker, the body drop is a pretty fair amount of work, but IMO the end results were worth the time. My truck is on the conservative side, & I figure total drop to be 4 1/2/ 6 1/2(including body drop). i wouldnt call it slammed, but its pretty low, & also rides & handles good. at the front, i couldnt say what would be the limit as far as what the inner fenders would alow, Im runnin a tilt front without inners. baggin would really be the ticket, but as we know the ride height is dictated by front geometry. my thoughts are that if you plan a mild body drop, it wont be that much more work to go a little more, & that will keep the suspension within spec @ a lower overall ride height. Good luck......crazyL
Old 01-07-2003, 08:26 PM   #10
jays68yak
jays68yak's Avatar
I think that truck would look better with a one piece window kit..........
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 01-07-2003, 08:33 PM   #11
crazy longhorn
2nd that! a 1 pc window would really put the "icing" on that truck
Old 01-07-2003, 11:13 PM   #12
Ackattack
Ackattack's Avatar
What all is involved in a body drop? Does it just require replacing the rubber body mounts with shorter ones? Or is it more envolved? (I'm guessing it is)
Ackattack is offline   Reply With Quote
Old 01-07-2003, 11:14 PM   #13
Stroker
CrazyL , I'm willing to ditch the inner fenders if thats what it takes to get the stance. 20-30 lbs off the nose should be good for the old truck. Someday you'll have to give us the full scoop on that tilt front end, that's in my wish list too, I'm just afraid that it's beond my abiliy at this point. I figure with all the cancer to repair on the underside of the cab I might as well go for the body drop while I'm at it. And I'm also in favor of changing the windows on that truck. BTW. Any one know what wheels are on that truck? I'm guessing their 18s. Thanks again....Stroker
Oklahoma
Old 01-07-2003, 11:46 PM   #14
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
they look like 20s to me
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-08-2003, 12:23 PM   #15
fastbagged68
fastbagged68's Avatar
If you want to go lower without messing with bags you can crossmember drop 1.5" with out messing with your steering to much. Good thing about this is you still have the same amount of distance between the ground and crossmember due to your dropping the whole frame into the crossmember more. I plan on doing a crossmembwer drop on a frame I have in my garage in hopefully about a month.
fastbagged68 is offline   Reply With Quote
Old 01-08-2003, 12:30 PM   #16
SCOTI
SCOTI's Avatar
Those wheels are 20x8 & 20x9.5's Billet Spec. Legacys.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-08-2003, 12:45 PM   #17
Reumster
L.E.D. Freak
Reumster's Avatar
How much clearance does the pumkin need to not hit the bed floor with a Early Classic bolt in C-Notch?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 01-08-2003, 03:10 PM   #18
Slammed67
Progress = 0%
Slammed67's Avatar
Early Classic doesn't make a c-notch to my knowledge. I think the one being referred to is made by Classic Performance Products, which is the one I'm using. The c-notches come with rubber bump-stops/snubbers. If you keep those in, you shouldn't have any clearance problems. If you take them out like I did, the pumpkin is going to hit the floor.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 01-08-2003, 03:50 PM   #19
SCOTI
SCOTI's Avatar
Talking
My set-up must be similar to slammed67's. I'm using my bed floor as the bump stop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-08-2003, 06:23 PM   #20
crazy longhorn
Custom clearancing that wood!
Old 01-08-2003, 09:23 PM   #21
XXL
Seņor Member
XXL's Avatar
Raising the bed floor 2" will give you full clearance if you leave out the rubber bump stops like Slammed67 mentioned.
Kenneth
XXL is offline   Reply With Quote
Old 01-08-2003, 11:12 PM   #22
PushinPebbles
My dad's 68
PushinPebbles's Avatar
No offense yall but if yall go through all the madness of a body drop................why not go for 3.5-4.0 inch body drop while your at it?............................thats what I was planning on when i get bagged but, those switches combined w/ nitrogen could eat up rocker panels that have been dropped......................no what I'm saying or did i bust my head on the hood again?
Jack P.P.
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 01-09-2003, 04:09 AM   #23
Reumster
L.E.D. Freak
Reumster's Avatar
Thanks XXL. If I install the kit I should be able to just raise a square right above the pumkin 2" and be good. But I will put a custom 1/4" bump stop just so I don't ever go metal to metal.
(406)675-8082
Old 01-09-2003, 07:43 AM   #24
XXL
Seņor Member
XXL's Avatar
Correct. You'll also probably have to take a small bite out of the frame crossmember just forward of the rearend. It's a flat-ish piece with a lip on either side. I had to cut an arc into the rear lip for the driveshaft to clear. I have heard that those with 2 piece driveshafts do not have to do this.
Kenneth
