K5-2WD=C5
the first day home
![]() ![]() ![]() doin surgery on the blazer!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by toplesskayfiver; 01-07-2008 at 01:24 AM. |
K5-2WD=C5
Re: my 1970 blazer build=4wd to 2wd
![]() ![]() ![]() ![]() ![]() ![]() ![]() 2wd center hump welded in ![]() went to the junkyard for my rear seat (86 suburban 3rd row bench) a hammer and a chisel are much easier to lug around than a huge generator so thats what i used ![]() it took me 30 minutes to decide which one to use ![]() |
K5-2WD=C5
i even took the carpet home to help me mark the bed floor
![]() ready to tack in the gas door (88-98) having filler neck problems though! any suggestions??? ![]() this is where im at. as far as the 4wd to 2wd conversion the frame is already drilled for the 2wd crossmember up front. can anyone tell me the best trailing arms to use for the rear on a 2wd conversion??? i recently found out the frames are different on a 4wd! can i use trailing arms from a longbed pick-up 2wd??? ![]() ![]() ![]() ![]() ![]() |
K5-2WD=C5
C10 Club Tennessee
looking good, sorry I'm not much help on the 4wd conversion. Get with Gringoloco, he's done it and his is awesome. I've got a 91 burb 3rd row for my backseat. Looks like they are good choices.
Is it going to be topless all the time like my roadster??
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Looks like a great project!
As far as trailing arms, they are the same length in 67-72 trucks. Long box, short box, Blazer, all the same length.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
When I did my flush mount door, I reused the stock filler pipe.
Hope the pics help. Welcome to the board, nice project. |
SKINNY TIRES RULE!
My understanding is that the trailing arms will fit, but you'll need to fabricate some shock mounts. If you plan on running airbags, you'll probably need to fabricate something anyway. LIVRAT has at lest a dozen conversions.
I believe that air ride is now making a 4-link system that is suppose to be a bolt in. I'm not sure if it is a bolt in for converted rigs though.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
All corect! The only differance in the rear of a 4x4 to 2x4 frame is the 4x4 does not flair out were the coil springs would mount like they do on a 2x4 frame. You can simply make brackets off the side of the frame to mount them to. I think ECE just did this in one of the mags! Just found it. Sport Truck mag and it is January 08 Vol 21 pg 68-71.
Hope this helps. Nice work by the way so far. Kevin LFD Inc. |
K5-2WD=C5
no i have a top in near perfect condition! how do you guys without tops plan on washing those trucks when the interior is in??? thanks for all the input so far! i will keep the progress pitures coming!
SKINNY TIRES RULE!
I've washed my truck with the top off before. It isn't that hard, just turn the water pressure down a bit so you can control it...
#12 | |
![]() Join Date: Apr 2004
Have you thought about using a four link instead of the trailing arm setup? I think that this would yield better results. Like previously mentioned Gringoloco and a few other have done this conversion. Try the search function using "conversion". Unfortunately "2wd" is too short for the search function to find. Where are you located? That thing looks familiar.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#13 | |
K5-2WD=C5
![]() Quote:
I have thought about that. The trailing arms seem to be easier, cheaper, and closer to an original 2wd!?!? Im not too familiar with how the four link works exactly? ![]() ![]() Last edited by toplesskayfiver; 12-31-2007 at 04:09 PM. |
The LuvShack Garage
Looking good so far
#15 |
A guy with a truck
Lookin' good.
![]() Lemme know if you have any questions on the trailing arms. It's all bolt-in once you get it squared up and holes drilled; there's even two holes already there for the center crossmember. The only snags are the upper spring and shock mounts. You will have to fab something for the upper springs since the frame does not flare out like a 2wd. For the shocks, I just moved the original crossmember that was at the front of the leaf springs back and used it for my upper shock mounts. Good luck -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#16 |
![]() Join Date: Feb 2000
Quite a project! Look forward to watching your progress.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#17 | |
K5-2WD=C5
![]() Quote:
For sure that you will be one of the first to know when im installing the rear arms! thanks in advance! im trying to get longbed setup from my buddys dad as i speak. any how, some more progress pics today! heres the top with all kind of overspray and junk on it ![]() belly is getting pretty sanitary thanks to a couple of sharp scrapers, o yeah and me too ![]() ![]() at first i shaved the passenger side sidemarker, i found some body filler and big waves in the panel in the near end of the pluging. so i got a different piece with my trusty hammer and chisel again.. i would like to have people vote on keeping the sidemarker lights or shaving them??? ![]() ![]() ![]() ![]() drivers side ![]() |
#18 |
Luv the Crewcabs
Welcome From Indiana, Look's Like You have a Good Start on your Project. I vote leave off the side Markers, I Like the Clean Look of the 67's w/out Them. Just would make Your's look a Little more Custom w/out them...........
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
#19 |
K5-2WD=C5
drivers side had been hit from the bottom here somehow..
almost all better now though. still not sure what im going to do with the filler neck yet??? more pics pleeaase!!!!!!!! ![]() ![]() ![]() ![]() Last edited by toplesskayfiver; 12-13-2007 at 11:53 PM. |
#20 |
K5-2WD=C5
i changed my mind on the rear seat. im going to use a 95 suburban 3rd row bench. and i scored my front bucket seats out of a 96 suburban!
#21 |
Are those front seat mounted? or are they just sitting in there?
#22 |
K5-2WD=C5
just sitting there. ill post pics later today, im going to attempt to mount them!?!
#23 |
In the middle picture I see the mounting brackets for the suburban third row seat, did you but those or make them. I bought my seats for this conversion already. I just need to mount them.
#24 |
K5-2WD=C5
actually i cut them out of a suburban at pick a part with a hammer and a chisel. once i got them home i grinded the sheet metal where they were spot welded to make em weak, then i pryed them apart using a hammer , a chisel and a steering linkage removal tool. i then grinded down the spot welds that were still stuck to the brackets to smoothen them out. ill post the pictures up later today! heres the donor suburban
#25 |
What did they charge you at the pick n pull?
