Old 01-01-2008, 01:42 PM   #1
mike nutt
69fatmotor
mike nutt's Avatar
ojoe's crewcab shortbed build
i figured it was time to start build thread on joe's (ojoe) shortbed crewcab 1/2 ton. here's a few pics to get things started , i'll let joe fill in the blanks.
mike nutt is offline   Reply With Quote
Old 01-01-2008, 01:45 PM   #2
mike nutt
69fatmotor
mike nutt's Avatar
Re: ojoe's crewcab shortbed build
more pics
Old 01-01-2008, 01:55 PM   #3
mike nutt
69fatmotor
mike nutt's Avatar
more pics
Old 01-01-2008, 01:59 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm subscribing to this one.
Keith
Convert to disc brakes.
Old 01-01-2008, 02:10 PM   #5
NEVERENOUGH
NEVERENOUGH's Avatar
I like it shortbed crew cabs are very cool. Lifted or lowered you can't go wrong. I will be keeping my eyes on this one also.
NEVERENOUGH is offline   Reply With Quote
Old 01-01-2008, 02:57 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'm signing up for this as well.... love the shot with the 20's on it. That is, and will be a sweet truck!
Looks like we need to get crackin lolife99!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-01-2008, 05:16 PM   #7
kevinr1970
To clarify, the black cab'd truck with the gold bed was a different truck than this one, right?
I have an '87 swb 2wd and an '85 swb 4x4. I would like to do a 4x4 swb crew. Just need the crew???
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-01-2008, 06:22 PM   #8
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Count me in on the subscription list. It gives me inspiration to cut my truck up!
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 01-01-2008, 08:46 PM   #9
streetstar
streetstar's Avatar
is that a 1/2 ton back half grafted to the 1 ton frame?
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 01-01-2008, 11:03 PM   #10
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Some constructive criticism - what size are those bolts holding the two frames together? Look kinda small to me, I wouldn't trust anything smaller than what holds the rear springs in their hangers. Also if it was my truck I'd weld up the rear vertical edges of the 3/4-ton frame to the outside of the halfton frame, and also the front vertical edges of the halfton frame to the inside of the 3/4-ton frame, wouldn't rely on just the bolts to keep things from shifting in case of an accident.
Other than that I think it looks pretty darn good, only thing it needs is a stepper bed and it'll be just perfect
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 01-02-2008, 02:54 AM   #11
lolife99
lolife99's Avatar
I think bolts are for alignment purposes. This makes is a fool proof method. I'm sure full welding will come next.
Keith
Old 01-02-2008, 03:51 AM   #12
OJOE
Crew Cut
OJOE's Avatar
thats correct. truck goes back on lift today for steam clean frame, rear disk brakes,frame weld (maybe boxed) dont want overkill. and frame paint. next will be the fuell system
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-02-2008, 01:26 PM   #13
cartman
Loving it !!! please keep us updated with the build. keeping my eye on this one.
cartman is offline   Reply With Quote
Old 01-02-2008, 02:06 PM   #14
BaddBusa2005
BaddBusa2005's Avatar
Very cool truck, good luck with it.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 01-15-2008, 01:50 PM   #15
mike nutt
69fatmotor
mike nutt's Avatar
here's couple pics of some of the latest progress.got the frame cleaned up and painted also installed the rear disc brakes and replaced everything else on the front brakes. also installed new 3.73 gear set with all new bearing. i myself had surgery friday to repair a double henior, so i want be around to help joe on this project for about a month or so.
Old 01-15-2008, 02:17 PM   #16
Hart_Rod
Hart_Rod's Avatar
It's about time you started a thread on this............. Looking good so far.
R/
Hart_Rod is online now   Reply With Quote
Old 01-15-2008, 02:19 PM   #17
ponjohn
What was the final length difference?
John
ponjohn is offline   Reply With Quote
Old 01-16-2008, 04:22 AM   #18
D-Day
Live fast, die young
D-Day's Avatar
Looking great. Love it.
D-Day is offline   Reply With Quote
Old 01-16-2008, 01:57 PM   #19
krazy10
was just looking at a lwb crew like this today. yours looks much better though..
and updates?
what are the future plans for this thing?
krazy10 is offline   Reply With Quote
Old 01-16-2008, 02:36 PM   #20
OJOE
Crew Cut
OJOE's Avatar
and updates?
will install a LT 1 /4L60E dailey driver
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 01-16-2008, 02:40 PM   #21
OJOE
Crew Cut
OJOE's Avatar
John
went from a 8ft bed to a 6ft should be 2ft shorter. i have not measured the wheel base.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 01-17-2008, 03:28 AM   #22
FlatBrokeRacing
FlatBrokeRacing's Avatar
The truck looks real good.
You guys turn out some real nice work.
FlatBrokeRacing is offline   Reply With Quote
Old 01-17-2008, 02:09 PM   #23
krazy10
will be an awesome DD, is it going to sit that high? or will it be lowered?
cannot wait to see it finished either way!
Old 01-17-2008, 02:34 PM   #24
OJOE
Crew Cut
OJOE's Avatar
just looks high, have already installed 3" spindles and 1" springs in front. rear has flip kit and c notch. it will come down about more 2" in in rear with the shackles i have to put on. also running 20x10 and 20x8 wheels. just finished running all new brake lines and changed out hydroboster to a vacum booster. still have to do fuel system.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 01-17-2008, 04:12 PM   #25
cartman
Did you notch the frame due to the fact that you are going lower, or is it nessary because of the axel flip? When I build my truck I want it at about the height that yours is now. I am figuring on just the axel flip and wondering if I'll have to notch the frame or not. It's not practical in the northeast where I live to go any lower with a truck that is a daily driver. The roads here SUCK!
